Can someone help me out with this one?
  • tucocaps
    • Apr 2013
    • 331
    • United Stated
    Paging BudM or TW or one of the other experts please, and thank you
    https://www.badcaps.net/forum/showthread.php?t=40616
  • tw2005
    • Oct 2011
    • 6458
    Re: Can someone help me out with this one?
    Tried my best.
    • Davi.p
      For BGA reflow experts...
      by Davi.p
      I have attempted all sumed very few reflow processes, and i need to make it better, how do you make yours to have sureness that the balls are really fully reflowed? My temptation was always to do "the slight move" touching very gently an angle, but due to some cases, but maybe 100%, where the previously half working device became totally shut off, i finally understood that the damn "move" makes the balls shorted, so what do you suggest?
      Thanks!.. Muchas gracias.....
      11-23-2024, 10:36 PM
    • SluggerB
      Cooling experts wanted.... (with pictures)
      by SluggerB
      So if you have been following my urine odor saga with my new PC, I believe I finally found out what is happening, my Northbridge heatsink is getting quite toasty, and other people online with my motherboard say the VRM's get hot as well. That may be the source of the odor I am smelling.
      Current setup
      The case has 3 fan openings, a 120mm front, a 120mm side, and a 92mm rear. Currently the only fan installed is the 120mm front. The CPU cooler has a side mounted 92mm fan on it (and that cooler is very cool, CPU temps are great). The only exhaust is from the PSU
      04-12-2022, 07:28 AM
    • thesteve
      Sony experts? 2nd bricked BAT Board after firmware update KDL-55EX720
      by thesteve
      So I bought another main board from eBay and the same thing happened.
      I got the firmware file from the Sony website. My model was listed and everything matched.
      sony_tvupdate_2011_4027_aaa_auth.zip was the file.
      Extracted to a folder: "sony_dtv0FA10A01A0A1_00000301"
      with file: 00000301_07e8046a.bin inside.
      Loaded it into the root of an otherwise empty USB thumbnail bought from around the same time as the TV. Not too old, not too new.. under 2Gig.
      The file reads perfectly. Lots of "disk activity"...
      07-17-2021, 04:59 PM
    • C152Heavy
      Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
      by C152Heavy
      Summary for TL-DR readers:
      • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
      • Have obtained Samsung schematic & service documents - Can upload if helpful.
      • Have read ALL applicable threads
      • C1818 and CP820 replaced as low hanging fruit
      • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
      • VCC pin (18) of PFC...
      01-11-2023, 02:53 PM
    • husnu16
      HP Envy X360 2in1 15-E1073CL la-m141p
      by husnu16
      Greetings, esteemed experts. Unfortunately, I couldn't clear the 13th generation BIOS file. I'd like to thank the experts who helped me with this.
      The device displays a delayed image and receives a warning that a corrupt BIOS has been detected. The HP BIOS recovery option is not available. Could you please repair the BIOS?
      - HP Envy X360 2in1 15-E1073CL
      - la-m141p rev 1a
      -sn: CND3233111...
      08-15-2025, 11:53 AM
