samsung PN42B400P3DXZA stuck in standby
  • joef1812
    • Sep 2014
    • 16
    • usa
    I have a tv that has got me stumped. When plugged in the red led in front glows red by I can't get the set to turn on with the touchpad button or a remote. I have 5.3 volts at the pin labeled standby.
  • joef1812
    • Sep 2014
    • 16
    • usa
    Re: samsung PN42B400P3DXZA stuck in standby
      09-07-2024, 05:50 AM
    • tvguy12012012120
      by tvguy12012012120
      02-07-2025, 05:13 PM
    • Ukdigger
      Samsung UE46f5000AK Stuck on Standby
      by Ukdigger
      When the Main board is disconnected, the back lights are off but tapping on the chassis makes them light up and all voltages are then good. Connecting the main board up makes the TV work normally until moved. LED INERFACE STRIP BN41-01971A has a short on the first 2 pins on the left of the picture, the cable tests good. All the other pins and all LED strips test good. Is there an easy way to fix the short or do I need a new interface. Any help would welcome.
      PSU number bn44-00610A L46SF_dpn
      1 B13v 12.4
      3 B13v 12.4
      5 Vamp 12.4
      7 Vamp 12.4
      9 GND...
      08-08-2024, 09:17 AM
    • Rusenga
      Samsung UA39EH5003R Stuck on standby
      by Rusenga
      Hi techs, I have a Samsung ua39eh5003r which switches on and then goes to standby. I have to wait for a day or two for the tv to switch on again, all the time it is stuck on standby. I have checked the voltages on the power supply board on both occasions when it is on and off and these are my findings:
      Connector CNM803:
      TV ON
      Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.96v; Pin6(BLU_ON/OFF)- 4.41v; Pin8,9,10- grnd; Pin11,12,13- 5.16v; Pin14(Power ON/OFF)- 3.3v
      TV OFF
      Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.06v; Pin6(BLU_ON/OFF)-...
      09-18-2021, 11:51 AM
    • ChristianBr01
      LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
      by ChristianBr01
      I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
      The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
      What I already found is that the 12.8V are not an the connector to the main board connector to the power...
      04-23-2025, 01:48 AM
