I have this Samsung and its sort of doing the same thing my other Samsung is doing. All Pixelated. I tried the logic board on the other tv but it didn't work. I haven't changed the one on this tv yet, so I'm tried to figure it out before I waste my time and money. I tried entering the test with with jumper on 3-4 and it didn't change. Any ideas?
Samsung SP-R4212 Logic Board?
by ohrenI hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
The models launched in 2018 and 2019 respectively.... -
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by C152HeavySamsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
Summary for TL-DR readers:
• VCC pin (18) of PFC... -
by YanlebHi all, I just want to share the repair of my 60PK550-UA TV set.
The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
C57: 3.30V
C61:...07-20-2023, 12:38 AM - Loading...
