Sony KDL-32L4000 chassis CZ1 No red standby LED but otherwise works
  • johnbinsc
    • Aug 2013
    • 24
    A minor issue but I thought I would ask...
    I have a Sony KDL-32L4000, north american chassis CZ1. It came to me with a bad A (main) board, with the symptoms:
    1) No standby LED light when plugged in
    2) Green LED turns on via top button or remote, but no backlight or picture.
    Initially I thought is was the G (power supply) board, but that checked out OK. When I disconnected the A board connector for the backlight control, the backlights lit up just fine, but still no picture. I think I have located the problem stalling the power-on process for this TV, but until I am sure I will leave that for another post.
    While trying to figure this out, I ordered a replacement A board off of ebay to verify that it was really an A board problem. (Note that there are at least 3 different A board part numbers for this TV/chassis, depending on the LCD panel manufacturer and TV serial number, and that many of them on ebay are mislabeled with the wrong number!) The replacement A board worked, and fixed the TV back to good working order. Hurray!
    Except there is one minor issue. With this replacement A-board, the red standby LED still does not light when the TV is plugged in or when it is powered off. Now I'm sure you are saying "Check the LED!", but I did that. The problem is not the LED itself. There is simply no voltage going from the A board to the standby LED pin on the connector for the IR/LED boards. I checked the LED driver transistor pair. They look fine, and are connected via some resistors directly to a pin on the MT5380 processor, and the trace seems to be OK (I removed the heatsink to verify this). So it looks like this pin out on the MT5380 is just not going high when the unit is in standby.
    And the crazy thing about this is that BOTH the old and the new A-board exhibit this problem.
    So, my question to the forum is:
    Has anyone else seen this? Is the failed standby LED a common problem on this TV, or other similar Sony TVs, or TVs in general? Since the Standby LED might be annoying for use in a bedroom, I thought maybe this was a feature to disable it, but I see no option for this in the setup menu. I did reset the new A-board to factory settings using the factory service menu, but still no standby LED.
    The lacking standby LED is a minor issue, but I worry that if this is really a dead output pin on the MT5380, does this foretell future problems with this main board? Do you think it is an electrical problem in the processor, or could it possibly be a firmware problem?
    Thanks for listening!
    John
  • rabbituk
    Sony HCD BX7700dbi CMT flashing standby
    by rabbituk
    I have got a Sony HCD-BX7700dbi that isn't worth a lot but I'm keen to learn how to repair and would appreciate some help with my train of thought. The protection circuit is kicking in and the standby light is blinking. It goes into protection mode within a second of powering it on.
    So far the relay on the power board that enables the main transformer clicks on and then off when powering on the unit. Looking at the schematics, the permanently enabled power rail called 'unreg sub' provides about 13.5VDC. Where the power comes into the main board on connector CN303, there is a diode...
    02-11-2025, 05:05 PM
  • cheeky2
    Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
    by cheeky2
    For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
    See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
    01-08-2024, 05:56 AM
  • androripara
    Sony Bravia 55HX820 - 4 times blinking red standby led
    by androripara
    i am trying to repair a Sony KDL-55HX820 led TV which is throwing error code 4 (standby led flashing four times).
    I followed the troubleshooting flowchart at page 69, and between pin1 and pin7 of CN6002 i am reading 1.91V so i guess i can rule out the B Board as the culprit.
    Before ordering new G* Boards (by the way, should i change both? it is not specified in the manual) i wanted to try and do more advanced troubleshooting since i've read in other threads people resolving their problems on the 46/55 HX 820/823/825 models by replacing the Samsung led...
    10-19-2023, 05:16 AM
  • denisten
    Sony STR-DB870QS standby transformer
    by denisten
    Hi everyone, i am a newbie here and i hope i will find the help i need. I have the above mentioned receiver with standby transformer's primary coil damaged. I have searched the net without success to find any tech data about this transformer. I have only the Sony part number1-437-313-11 and TAM Malaysia M0126. I guess i could find replacement for it, but i need to know the secondary coil voltages and VA. It is 220v on the primary. It has 5 pins on the secondary, the outer two are not used and i have 6.5 ohms between pins 2and 4, 3,9 ohms between 2 and 3, and 3,6 ohms between 3 and 4. Can someone...
    04-14-2023, 03:24 AM
  • Carlos#2003%
    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
    by Carlos#2003%
    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
    02-15-2024, 07:52 PM
