Panasonic TC-P65S2 adding fans?
  • blackoper
    • Aug 2014
    • 3
    Panasonic TC-P65S2. I've just recently repaired a bad SC board (sent to moduslink) and bad ETX2MM813MSS power supply sub board (230V 1000uF cap blew). It appears when the cap blew out it caused the problem with the SC board as that was being directly fed by the power.
    From what I've read, the main issue causing the Panasonic plasmas from 2010 to have part failure is heat related. So would adding two or three 120mm fans prevent future problems? I noticed that in following years fans have been added.
    If so should I just use a temp sensor to kick the fans on and off or is there a good place to pick up the AC current after the tv has been started so the fans turn on and off with the tv
    Fans would be powered by something like this AC to 12 volt switching power supply: [http://www.ebay.com/itm/221423157587...%3AMEBIDX%3AIT If i have to pull it off the AC main
  • emil_t
    RTX3090 working fine but fans not spinning
    by emil_t
    Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
    04-12-2024, 06:54 AM
  • BigPete
    Panasonic Heatpump Dryer Repair
    by BigPete
    I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
    The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
    In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
    Unfortunately the whole machine has to come apart to fix it.
    I have...
    11-01-2025, 06:40 PM
  • Andre Gilbert
    by Andre Gilbert
    Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
    Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
    11-20-2024, 08:52 PM
  • b-slayer
    Asus Strix-G15-G513RM fans don't work
    by b-slayer
    I have an Asus Strix-G15-G513RM, who starts normally, but as the fans don't work, it stops and is really really hot,
    The Bios was the latest one, (327), but I managed to downgrade it to version 325 to see if it changed something,
    (as I read somewhere that a corrupted bios can explane my problem), but nothing, it just went full blow during the downgrade,
    (so now, i can say that the fans are fonctionnal), but as it restarted, the fans won't turn at all again.
    ah, and in the Bios, even when the temperature is really hot, the fan are a 0 rpm,...
    09-04-2025, 04:58 AM
  • craftech
    Adding fans to Panasonic Plasma
    by craftech
    Recently replaced SC and surrounding boards on a Panasonic TC-P42X1 due to standard 7-blink failure code. There are no cooling fans on that model. Searched the forum for a mod to add them, but didn't find one. Forgive me if I didn't look hard enough, but does anyone have any suggestions on how to do that. I have quite a few quiet computer case fans. Zip ties and a separate power supply blowing in maybe?
    Thanks,
    John
    09-16-2018, 07:44 AM
