Panasonic TC-P65S2 adding fans?
+ More Options
Posts
  • blackoper
    • Aug 2014
    Panasonic TC-P65S2. I've just recently repaired a bad SC board (sent to moduslink) and bad ETX2MM813MSS power supply sub board (230V 1000uF cap blew). It appears when the cap blew out it caused the problem with the SC board as that was being directly fed by the power.
    From what I've read, the main issue causing the Panasonic plasmas from 2010 to have part failure is heat related. So would adding two or three 120mm fans prevent future problems? I noticed that in following years fans have been added.
    If so should I just use a temp sensor to kick the fans on and off or is there a good place to pick up the AC current after the tv has been started so the fans turn on and off with the tv
    Fans would be powered by something like this AC to 12 volt switching power supply: [http://www.ebay.com/itm/221423157587...%3AMEBIDX%3AIT If i have to pull it off the AC main
  • emil_t
    RTX3090 working fine but fans not spinning
    by emil_t
    Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
    04-12-2024, 06:54 AM
  • Andre Gilbert
    by Andre Gilbert
    Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
    Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
    11-20-2024, 08:52 PM
  • craftech
    Adding fans to Panasonic Plasma
    by craftech
    Recently replaced SC and surrounding boards on a Panasonic TC-P42X1 due to standard 7-blink failure code. There are no cooling fans on that model. Searched the forum for a mod to add them, but didn't find one. Forgive me if I didn't look hard enough, but does anyone have any suggestions on how to do that. I have quite a few quiet computer case fans. Zip ties and a separate power supply blowing in maybe?
    Thanks,
    John
    09-16-2018, 07:44 AM
  • AquaMan Ua
    Problem with PANASONIC CF53 laptop after changing BIOS settings
    by AquaMan Ua
    Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
    05-17-2025, 09:40 AM
  • JayPoorJay
    Hot Water Rad - A Few ECU Fans and a Timer Switch
    by JayPoorJay
    Good Afternoon, Good People.
    I know this will be an elementary little project for most if not all of you, but I thought I would write a post and get put on track, rather than bumbling my way through it with all kinds of trials and errors.
    I REALLY would appreciate y'alls help.
    This is the problem - My wife and I purchased a big ol Victorian/Colonial House in NYC two years ago. The kitchen is surrounded on 3 sides by exterior walls, there is also a 1/4 of the kitchen floor (ceramic tiles) that has a crawl space underneath, and the kitchen gets FREEZING cold...
    10-29-2024, 12:54 PM
