Westinghouse 42" HD flat panel question
  • Tedybear
    • Sep 2014
    • 104
    Have a chance to pick up a Westinghouse 42" flat panel for a good price--and it's got an issue.
    Current owner says the screen was hit by something but did not crack the glass that he is aware of.
    I've borrowed the photo he sent in of the screen. Just looking for possible ideas of how bad or good this could be. It's priced low enough to get my interest. But I'm concerned about the screen.
    I'm thinking maybe the edge connector came loose from the impact--in that case maybe some foam tape to act as a 'wedge' might bring it back to life. But I'm not sure.
    Any feedback would be welcome. I'd like to setup something quick if this is a good solid chance-
    (that's as good a screen shot that I could grab. The one with the TV off looks normal?)
    Thanks!
    S-
  • Tedybear
    • Sep 2014
    • 104
    Re: Westinghouse 42" HD flat panel question
    So should I roll the dice and take a chance?
    • Clydeuk
      • Jan 2012
      • 193
      That looks like a cracked panel to me from the photo, I would steer clear. The damage is probably not visible externally but with the display on it's a dead giveaway.
      • Tedybear
        • Sep 2014
        • 104
        Well, that's part of the fun. He's asking $30 for it, or best offer. I suspect (sense the other photo shows no damage) the broken area is above the trim area, probably right along the strip that has the electrical contacts.
        If I can get him down to $20, would it be a fair deal? I could always part it out.
        Thanks!
        S-
        • Tedybear
          • Sep 2014
          • 104
          Well, if anyone else cares to weigh in.
          Knowing that it will likely be a parts machine. What would be a fair price? Would it be worth throwing a twenty on it just for the experience?
          Or just say nope and continue to try and find a decent 'working' set that has an intact screen. Looking for options and opinions.
          (Heck, if I can find a 32" westinghouse? I saved the guts and no interest so far from anyone wanting to buy it. The screen is 100% <G> Shame I can't modify it for the 42".)
          S-
          • mmartell
            • Oct 2013
            • 3189
            I would guess the panel is fubar as well, and that being the case there won't be much to learn but how to loosen the screws to harvest the boards
            • Tedybear
              • Sep 2014
              • 104
              Well. Looks like I'll see if I can pick the set up for a reasonable price.
              Would the $20 be a decent price? (He's asking $30, but I can probably kick him down a bit) Considering it would be a 'harvest' job, I can probably sell the parts as needed to other members and on eBay to recover the costs.
              • howardc64
                LG 49UJ6500 LCD panel lighter band that goes away
                by howardc64
                49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                02-19-2023, 12:13 AM
              • triplefour
                SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                by triplefour
                TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                tcon is built into mainboard.
                Only one cable goes to panel boards.
                there is a cable from one panel board to the other that links them.
                cost cutting measure that results in us having harder time to diagnose.
                removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                07-28-2022, 07:59 PM
              • maneatingmonkey
                Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                by maneatingmonkey
                I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                03-27-2024, 07:17 AM
              • bohaboha
                PHILIPS 32pfl3403d Flat-panel TV Upgrade Assistant problem
                by bohaboha
                Hi trying to update my Philips cause in retail mode not possible to get out from it i get this message in update site : Error message: no data exception. Your reference: Request ID (server_1930105)
                how to fix it thanks
                02-05-2025, 09:23 PM
              • howardc64
                Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                by howardc64
                • Prior owner tried a replacement main board. No difference.
                • Samsung 2x red blinking standby LED = panel fault
                • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                07-19-2025, 10:54 PM
