Difficulty accessing Service-Menu, Pan TH-42PZ700BA
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Bit of an odd one.
    The usual access method gives the 'self-test' and factory-reset mode, but not the service-menu.
    42PZ700U Service-Manual says--
    While pressing [VOLUME ( - )] button of the main unit, press [RECALL] button of the remote control three times within 2
    seconds.
    But--There's no 'Recall' button on the original correct remote for the set. (UK set)
    --Tried the return button, nothing, as well as exit and guide buttons,--Think now, Ive tried 'em all!
    Tried the 'I' (info) button, both continuous and three times, both give the self-test/reset (Which is annoying, as the set then goes through all the tuning set-up and all that jazz)
    Tried the 'Menu' button, both continuous and three times within 2 seconds--again (and expected) the reset/self-test.
    Any ideas?--Ive another PZ70, Never had a prob accessing on that one, but this is a PZ700
    TELEFIX
    Re: Difficulty accessing Service-Menu, Pan TH-42PZ700BA
    PZ700U is US spec, entry mode is different to BA. Not sure if it's different to "B" though.
    • kasfamily
      • Aug 2014
      • 772
      • Russia
      show photo the remote control
      • tw2005
        • Oct 2011
        • 6458
        in the 80BA it says , While pressing [VOLUME ( - )] button of the main unit, press [0] button of the remote control three times within 2 seconds
        Could be similar?
        • dkneyle
          Sharp LC-37B20E difficulty accessing service mode
          by dkneyle
          I'm getting a blink code which indicates a lamp problem. Following guidance I see on YouTube etc, the suggestion is to re-set the lamp failure counter before going too far further. I use the technique described in Sharp service manual to enter Service Mode (hold down INPUT and VOL DOWN key simultaneously then power up) and it seems to half get there before shutting down again. The Power LED goes through a different sequence than standard start up, a brief flash from the backlights, audio static burst, then it shuts down again.
          Do you reckon things are too far gone and the set is...
          07-14-2019, 10:52 PM
        • gulencocuk
          Lenovo 14IHU5 - Difficulty copying SN MTM and DMI from corrupt BIOS
          by gulencocuk
          Device: Lenovo 14IHU5
          I could not copy the proper blocks from the old&corrupted bios to move my Windows license and device identifier information. Currently, it's working with the clean bios but with an empty serial number and model information.
          Which regions should I copy from the corrupted one? Thanks...
          08-13-2023, 10:18 PM
        • BeneathTheSurface
          Need assistance accessing UEFI of Surface Go
          by BeneathTheSurface
          Previous owner (that I have no way of contacting) thought it'd be cute to cap the battery off at 50% and then lock the UEFI. M$ has been anything but helpful while trying to convince me the only path is to swap+purchase a referb. Much to my joy, I found this forum just as I was losing hope.
          I have FPT, but haven't found a satisfactory tutorial. So if there's a good one floating around, please post it. Otherwise I'll get you all a dump ASAP.
          05-07-2021, 10:37 PM
        • Ady2017
          Difficulty trying to match ESR of a replacement capacitor
          by Ady2017
          Hi all
          I am trying to find a replacement capacitor for a CapXon KM 100uF 400V. I have read that the big ones really go wrong but it is the last one left on the power supply board that has not been changed and the TV is still playing up so it is getting swapped too.
          I have read that I need to find a replacement cap with the same or higher ripple and the same or lower ESR, with all the usual being matched. The ripple is easy to match but the ESR seems to be a challenge.
          From the KM datasheet I have got, dissipation factor = 15% (therefore 0.15).
          I have...
          10-13-2020, 04:56 AM
        • yoritomo
          Philips 40PFK4100/12 CI key fail error
          by yoritomo
          TV Philips 40PFK4100/12
          Chassis TPN15.E LA
          Hello everyone.
          I am facing a red message above the screen permanently, also the image is greyed and the TV is unusable as is in any sources.
          Of course I tried everything basic or a bit advanced, so I updated the firmware to version 2.550 which did not resolve the problem.
          Accessing the secret menu by I have access to 3 interesting parameters regarding this issue
          -DRM Warning
          -CIPlus Query
          -CIPlus update
          Obviously I tried to set DRM warning to OFF but this don't...
          08-17-2025, 12:27 PM
