Smart tv Zephir no imagine
  • labello
    • Mar 2018
    • 278
    • italia
    #41
    Originally posted by labello
    Hi guys i have this kind of smart tv , audio is present , backlight is present too but no picture. I measured voltage on the pannel and seems OK.. but I'm not sure about that, I'll post the measurements. Thanks for the reply
    VGH 36.14
    VCC 12.24
    VGL -8.890
    VAA 13.30
    (VDD 33) 3.3
    VGL_TFT 5.977
    VSSI -5.978
    VGH. 36.09
    VCC. 12.25
    VGL. -8.880
    VAA. 15.25
    (VDD 33) 3.323
    VGL_ TFT. 5.973
    VSSI - 5.970
    Here the difference after the (mod) thanks
    • lotas
      • Jan 2016
      • 4859
      • Russia
      #42
      You did everything correctly, the panel went into test mode, if there are no defects in the image, then the problem is either in the cable itself or in the motherboard (firmware, processor, dc/dc converters, ...).
      • Diah
        • Feb 2013
        • 6562
        take out the heatsink from the SoC and show here good photo of it and around
        • lotas
          • Jan 2016
          • 4859
          • Russia
          #44
          The radiator here isn't easy to remove; it's held in place by four pins soldered to the back of the motherboard. Without experience, you could ruin the motherboard.
          • Diah
            • Feb 2013
            • 6562
            first think i asked him to check LVDS signal ......MB already ruined
            • lotas
              • Jan 2016
              • 4859
              • Russia
              #46
              If there were signals on LVDS, there would be an image too.
              • labello
                • Mar 2018
                • 278
                • italia
                #47
                Hi guys I already back home from the work, so remove the heatsink ? Sure give me 5 minute. I'll be back.
                • labello
                  • Mar 2018
                  • 278
                  • italia
                  #48
                  There you are.. I have quite experience on soldering and desoldering stuff...
                  • Diah
                    • Feb 2013
                    • 6562
                    start to clean the SoC and all around with alcohol , look in my eyes moister was under the heatsink
                    • lotas
                      • Jan 2016
                      • 4859
                      • Russia
                      #50
                      It's just thermal paste.
                      • Diah
                        • Feb 2013
                        • 6562
                        after you clean around and be sure no crack at any SMD Soldering Parts, put glue paper which used for wall or can painting over all the soc and 2 CM round it, cover them with 2 Layers of the glue paper,, and use your hot air gun only heat the area i marked until the paper burn to brawn black
