YSUS Board for LG 60PC1D
  • tech2014
    • Aug 2014
    • 807
    I found the 5v line on the YSUS board was shorted, reading 4 ohms. I found it when I connected the 5v connector from the YSUS board to the main p/s as the voltages all dropped when connected. I also connected my DC regulated p/s to the YSUS board 5v line and as soon as I powered it up, the voltage only went to about 3.4V and the current was very high.
    The board number is EAX35342701. Does anyone know where I can get this board? I already checked shop jimmy site and its out of stock.
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • MalodicOne
    Macbook 820-02773 Board short when trackpad connected
    by MalodicOne
    Original fault was customer spilled milk on unit, no corrosion was found on the board. Took mainboard out of original case and LCD and swapped it into the fully functioning case and LCD.
    Shorts show up all over the board when trackpad is connected only. Trackpad is used and fully functioning from another unit of same model. Voltage injection causes trackpad connector to get hot but nothing else, swapped on board connector to rule that out, same issue. Diode reading on IPD_MCU_INT_CONN is higher then reference board @ .935 expected is .803. Shorts show up on PPVBAT_AON_CHGR_REG and...
    03-31-2025, 09:54 AM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
