LG 32LK330 - Sound but no video on Tuner
  • JeffJ
    • Apr 2012
    • 189
    I have an LG 32LK330 LCD tv here that works perfectly fine on all input sources except the Analogue/DTV Tuner. I get sound on the tuner but no video output. The menus work, but its just black.
    Is this a tuner issue? Does any one have any experience with this, if I source a tuner and solder it in, would it be probable that it will fix the issue?
    Thanks in advance!
  • tvrepairguy
    Brdcst Engineer
    • Jun 2014
    • 15
    Re: LG 32LK330 - Sound but no video on Tuner
    could be a lot of things. best bet is to replace the board...between $50-$90. its better than buying a new one
    • JeffJ
      • Apr 2012
      • 189
      I know this was ages ago, i finally got around to poking at this unit again. Turns out it was a firmware glitch. I went into the service menu. entered the panel calibration, then changed the country local to something different and then back to my country. This causes the tv to hard reset. and the Analogue and digital Coax video input now works again. Resetting the tv from the User accessible consumer menu did not help this.
      • Max514
        Samsung UN55H8000 sound but no backlight no video
        by Max514
        Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
        The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
        I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
        • Unplugging the main board cable at the power supply >>> backlights came on.
        • BLU_ON signal from the
        04-14-2022, 10:34 AM
        GeForce RTX2080 Super Aero video gaming card issues help need
        This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
        Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
        05-07-2023, 08:12 AM
      • ajshoe
        vizio E60-E3 backlights, sound, no video
        by ajshoe
        Have a free Vizio E60-E3 pickup - sound and backlights work. set turns on and stays on for a period then cycles off and back on. NO VIDEO. If I remove left side (from front of TV) of TCON cable - set has pic on right side (from front of TV) with white screen on left side. With right side TCON cable disconnected - no pic on either side.
        Does this mean remove right side (from front of TV) tabs ?
        Like a second opinion before possibly destroying set....
        04-07-2023, 01:59 PM
      • japlytic
        Gigabyte Z690 UD AX DDR4 distingusihing failures+default video
        by japlytic
        On this motherboard with a CPU (requiring discrete graphics) supported by the BIOS (version F3) and a new video card, it has a beep code indicating a CPU failure while the onboard diagnostic LEDs indicate a video system failure and using a different motherboard of the same model had the same result despite confiriming that the new video card along with the power supply as well as the connected display/cable was operational in another system.
        So therefore, I've found that the Video diagnostic LED illuminated before CPU diagnostics were performed and since the CPU has failed, video diagnostics...
        12-30-2022, 11:12 PM
      • niimi93
        Laptop No Longer Recognizes TV Sound Bar
        by niimi93
        I'll begin with the fact I don't know what change I made to my laptop that triggered this cause. I use my laptop as a pseudo PC by just connecting it to my big smart TV and using a wireless keyboard and mouse. I have a sound bar connected to the TV via optical audio toslink cable. I have game consoles connected to the TV. The game consoles and Netflix/other media apps installed on the smart tv all work properly playing sound through my sound bar with no issues. My laptop, until recently, was playing sound through the TV sound bar just fine as well. I don't know what change I made, and I don't...
        04-25-2023, 07:43 PM
