Toshiba TV and the DoSed remote control...
  • Tom41
    • Oct 2005
    • 336
    • England
    We recently got a brand new Toshiba LCD TV with HD capability. The set itself works perfectly, but actually causes a separate problem. While the TV is on, the digital cable TV box does not respond to its remote! If I turn the TV off or put it to standby, the box starts responding again - only to stop when I turn the TV back on.
    It's as if the TV is somehow doing a DoS attack against the remote control, but I think that's highly unlikely
    The cable TV box DOES respond to the front panel buttons while the TV is on, and the other two remotes there (DVD recorder and the TV remote itself) are not affected. It's really annoying having to get up and go to the box to change channels, or having to standby the TV when I want to type in a new channel number. As you can imagine, using the 'red button' interactive features is impossible if you can't see the screen while using the remote!
    Anyone know why this might be happening, and anything I can do to stop it?
    You know there's something wrong when you open your PC and it has vented Rubycons...
  • Maxxarcade
    • Jul 2006
    • 973
    Re: Toshiba TV and the DoSed remote control...
    Does the affected remote use RF or infrared? Try moving the cable box away from the tv a bit more. The backlight is probably putting out interference at the same frequency range as the remote.
    On a side note, I have those small compact flourescent lights in my home theater room, and when I turn them on, sometimes they put out so much infrared noise that my projector will turn on
    I also noticed that the remote receive light on my media center flickers when I turn the lights on. When I was using incandescent bulbs I never had the problem.
    • Tom41
      • Oct 2005
      • 336
      • England
      The affected remote apparently uses IRDA. It was designed originally so that by changing a 'player' switch at the bottom, you could do multiplayer games with 4 remotes. The player switch makes it so they can all transmit at once without interfering with each other.
      In practice though, the multiplayer games never materialised, and changing the 'player' switch doesn't seem to make the remote work.
      The TV is certainly not sending any information back to its remote via IR - are you saying that the backlight tubes are flickering at a similar frequency to the one the IRDA remote is using?
      • Maxxarcade
        • Jul 2006
        • 973
        The backlight, or some other component of the TV. All I know is I've seen some high frequency inverters do weird stuff to IR remotes.
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          well you probably dont want to turn down the backlight so i guess you will have to get something like a remote extender with the emitter stuck right on the cable box ir sensor. then have the target closer to you or somewhere else in the room where it works.
          • Harvey
            • Apr 2007
            • 264
            If its a NTL/Virgin cable box, I have some vague recollection of certain TVs putting signals out the SCART connection and messing up the remote - but I've had a search and can't find anything on the forums.. You might just want to try removing the SCART if you have one to see.
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              well if its got some problem its gotta be ntl
              • chipper
                • Aug 2008
                • 95
                It sounds like you may have a situation where the remote and the box are both on a different channel when it comes to commands. This can happen with non-brand matching controllers (like boxes and remotes) , or even a 3rd , the tv controls themselves.
                Once you see that they all do weird things , it's time to reread the installation procedures for all 3 , the tv , remote and box. Look for something in them that specifies different procedures for different component controllers. Don't do anything until you are sure you have sought out some mention of problems due to improper installation. My guess is , it is in the remote installation procedure , you have to be extremely careful what buttons you press , and for how long (exactly - seconds).
                That would be why you press "off" (power button) , while on , it goes off just enough to cause the action to occur , but it won't stay off. The remote is a secondary control to the box [comes with box-not tv] (which is a secondary control to the tv controls themselves) , in that order. So , read installation manuals in that order and confirm normal operation of each before moving on to the next one : tv / box / remote.
                • tmhobadcap
                  Pioneer VSX-522-K remote control not working???
                  by tmhobadcap
                  I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
                  At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
                  12-24-2020, 01:44 AM
                  09-06-2024, 05:27 AM
                • piipo
                  Old Privileg 5.1 speakers remote control question
                  by piipo
                  Hi, I have an old Privileg brand 5.1 speakers. I have lost the remote control. I have an universal Harmony remote but there is no Privileg brand in it's software to add. Does anybody have an idea what alternative brand for a remote can I try instead? I'm attaching an image of what the speakers looks like. The image shows 2 main speakers, they are 5 + 1 in total. Thank you very much
                  09-18-2024, 01:55 AM
                  09-06-2024, 05:59 AM
