Plasm tv repair WARNING !!
  • RCA2000
    • Sep 2014
    • 111
    I have been in this repair field for a long time--so I know of what I am speaking. Up till last year--I did this stuff every day. I was the "master tech", the one the "kids" (novice , young "techs", who did screenings and minor repairs) went to--when there was a problem. I also repaired boards--when this was possible--for the other techs then to use.
    I worked on a LOT of plasma sets. These really should be called "fluorescent tv" sets--since the phospor--NOT the plasma 9inoized gas) is what produces the picture--but I guess that would not "ring " right wiht the masses.
    Anyway--there is something everyone MUST be aware of--when replacing ANY PDP panel.
    YOU MUST DISCHARGE THE VS SUPPLY.... BEFORE INSTALLING THE ADDRESS LINES !!!!
    NO exceptions !! If you fail to discharge the VS supply on the power supply board, (usually around 60-75V), you run a HIGH risk--of blowing out one or emore driver chips on the address lines on the bottom of the panel.
    I HAVE seen this happen. The result is usually a column that is dead or full of "cross talk" (noise) and NOT useable. And one would NOT know--if it is a bad PDP--or one that was "blown out" by a loaded VS line..
    This comes directly from Samsung--BTW--in a training seminar I had.
    SO--take a resistor, of say 1K or so, and apply it to the VS out of the supply and ground and discharge for at LEAST 5 seconds--before connecting the address lines. (WITH the set unplugged--of course !!)
    This will protect those fragile address chips on the bottom ribbons--from getting killed by a surge.
    Also--NEVER--EVER-- operate the panel without the sink strap over the address chips at the bottom--even for a SECOND !! If you do--it WILL kill one or more chips... and the PDP panel I WATCHED a couple of 'techs" do this and ruin TWO panels this way !! They would NOT listen to me--when I warned them.
    Good troubleshooting..
    RCA2000--Jack S.
  • tw2005
    • Oct 2011
    • 6458
    Re: Plasm tv repair WARNING !!
    RCA2000--Jack S.
    Thanks for the tip and yes, I & suspect a few of us have inadvertently killed a panel doing this.
    The one I killed was also a Samsung. I powered it up forgetting the power lead to those address buffers you refer to.
    Connected and it arced as I did. Ended up with a dead ribbon, still hopeful it was not I ran the Tv gradually losing half the panel before I realised my next monumental stuff up.
    I had removed the long aluminium strip not realising it was in fact a heatsink.
    Yeah, TV was fixed , now junk.
    Fortunately with some of the Panasonics I look at, they have individual heatsinks integrated with the ribbons so lesschance of a fast burnout.
    Still, I often mention when disconnecting now any of the power from those buffers and sustains to let the voltage bleed off or better still, meter it first to make sure they're not hot from the caps holding charge.
    • ugamazing
      Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
      by ugamazing
      I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
      08-31-2022, 07:34 AM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • Syseng
      Lenovo P14s Gen 5 SVP unlock
      by Syseng
      This sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
      The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...
      06-22-2025, 07:44 AM
    • Stanley1843
      Screen Display Vertical Multicolor Lines
      by Stanley1843
      Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
      06-29-2024, 11:54 AM
    • feherhollo
      WSON8 NEW Bios Chips READ, ERROR, ETC.
      by feherhollo
      I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
      I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
      For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
      11-26-2023, 09:33 AM
