Standby Voltage
  • tech2014
    • Aug 2014
    • 807
    Standby Voltage
    Isn't the standby supposed to be on when the AC is plugged in and goes into full power mode when the power button is pushed.
    I have a tv that has standby LED but the standby voltage keeps jumping around between 5v and 0.5V. Any reason why?
    Re: Standby Voltage
    The standby power supply is an always on power supply which runs the minute the AC is applied.
    So if you disconnect the load from the standby, will it become steady?
    It is in the loop (shutdown/startup) right now which can be due to bad cap, too much load being applied, shorted/leaky rectifier in the secondary side, etc.
    Make/model/pictures of this unit?
    • tech2014
      • Aug 2014
      • 807
      Re: Standby Voltage
      Hi budm. Here is the link to the original thread on this tv. https://www.badcaps.net/forum/showthread.php?t=39729
      I am leaning towards the main board being the problem. When I disconnect the load there is no change. I notice that I never get a VS_ON signal which is from the main board. I tested it with load and removed each board and still no VS_ON. The 5V still goes between 0.5 and 5V no steady 5V.
        Re: Standby Voltage
        So the standby still bounces with main board out? Could be bad start up capacitor.
        • tvguy12012012120
          by tvguy12012012120
          02-07-2025, 05:13 PM
        • x_orange90_x
          Samsung UN55KU6300F no standby voltage
          by x_orange90_x
          I have no standby indicator light and no light on the optical port. I checked the standby voltage on the two mosfets in the top left and they both read 30mV. I checked the fuse and it has continuity. I also checked the voltage on the two large 450v caps they both read 153v. All of these voltages are the same with and without the main board connected as well as with backlights connected/disconnected.
          Nothing looks obvious like a burned ceramic disc cap or bulged electrolytic. No burned resistors, diodes, or anything like that....
          05-21-2025, 09:59 PM
        • Bad_IC
          Philips TV 37pfl5604h/12 no standby voltage
          by Bad_IC
          I have a problem with this TV, the standby voltage is not present. I have checked the components around the IC fsq510's area and they seem to work, also replaced this IC but the problem persists.
          These are the voltages in some pins of IC fsq510:
          Vcc=18v
          D=320v
          Vstr=154v
          Unfortunately, I couldn't find the schematic
          What else could I check?
          Is it possible to provide standby voltage from an external source to allow the TV to turn on?
          Thank you​...
          11-08-2024, 01:07 PM
        • brock-s
          Asus GL503GE 3.3 standby voltage low
          by brock-s
          An Asus GL503GE laptop arrived that had had a screw dropped on the motherboard while the battery was connected. This resulted in a physical damage to the 3.3v / 5v voltage controller RT6575DGQW (pu28 on schematic, page 40). Additionally, the trace to pin 12 (VIN 19v supply) was burnt.
          Replaced the RT6575DGQW with a new one, repaired the damaged trace. Only getting 0.7V instead of the expected 3.3v standby voltage (3V_S5 on schematic).
          Replaced the AON7408 PQ60 mosfet from a donor board as resistance was low on the gate (I did not write this value down, as I optimistically...
          07-13-2023, 03:43 PM
        • danny34
          E15 Gen2 Intel i5 - doesnt start & jumping voltage
          by danny34
          I have an E15 Gen2 with Intel i5 and need your help.
          It doesn't start and here's what I've already found out:
          All voltages are available.
          However, the PU8 (RT3612) does not switch the mosfets for +VCCIN.
          On the PU8 I measured 3.3V at pin 23 (VRON), but it drops to 0V every about 3 seconds. This voltage comes from the IT8227E.
          VCC from IT8227E has exactly the same symptom. Every 3 seconds the voltage briefly drops to 0V.
          In the end I saw that +1.8VALW (VCC from IT8227E), +0.6VS, +2.5V_DDR & +1.2V drop to 0V...
          12-13-2024, 04:20 AM
