KDL-40z5500 SONY
  • abdekader
    • Jul 2014
    • 73
    • Turkey
    KDL-40z5500 SONY
    I have KDL-40z5500 SONY , the red led blinks 6 times what's the mean that, please? >>> what's the problem ?
    i can't find manual for this problem
    Electronic Engineer from Syria,Aleppo
  • Nicktronic
    Sony XBR-65X850D 2 Red Blinks
    by Nicktronic
    I have the subject TV and it will work normally sometimes but suddenly go black and give the 2 red blinks blink code. When this happens, I check the power supply board voltages and all I have is the Standby 3.3V and BL_ERR 2.2V. When it's working normally, all power supply board voltages look normal and stable. I've checked the backlights with a tester and they all test good. I've also read that the 2 red blinks is a faulty power supply board, so could it be throwing up an erroneous BL_ERR?
    Any Sony experts out there that can help??...
    11-19-2023, 06:51 AM
  • x_orange90_x
    Sony KD-60X690E 6 Blinks, no image
    by x_orange90_x
    I just got this today and it has the infamous 6 blink code. I've read it's quite possibly bad backlights, and I intend to check them soon. However, I was just curious if the Sony logo should it's shouldn't be appearing briefly between powering on and the light starts flashing. I've read at least one other person had the logo flash quickly, but mine does not show anything at all, not even a flicker. The green light comes on and after about 5 seconds the red light flashes. So I'd expect in this 5 seconds to see the logo. This leads me to believe it could be a power supply issue.
    I...
    12-10-2024, 09:10 PM
  • dominik0801
    SONY KDL-43W755C | 5 blinks stand-by LED
    by dominik0801
    Hello guys.
    Today I got this TV for free, the friend included a "new" (used) TCON with it, since he told me, that doesn't work either.
    With the stock TCON, this TV turns on, stays on, but the screen only has 5 RED vertical lines on it, and that's it.
    Backlight stays on and is fine.
    With the "new" TCON, the TV turns on, shows SONY logo, some spinning circles, then the TV goes blank, and the stand-by LED is blinking 5 times, won't react to anything.
    I have read some forums, where it's been told that the part number is not always enough...
    12-18-2023, 11:40 AM
  • chrisl32
    Sony KDL-46EX500 2 blinks, then 6 blinks
    by chrisl32
    It is about a Sony KDL-46EX500 that was struck by lightning.
    I did not see any visual damage on it.
    An internet provider box and the Ethernet port of an AppleTV were also out of order.
    My following remarks refer to this schematic ; https://www.badcaps.net/forum/attach...2&d=1378923377
    posted by https://www.badcaps.net/forum/member.php?u=16669.
    Thanks to him :-)
    There was nothing on screen, and after a few seconds, it gave the 2 blinks code.
    As I had no 394V on the C6516 capacitor; I decided...
    03-29-2021, 07:37 AM
  • Carlos#2003%
    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
    by Carlos#2003%
    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
    02-15-2024, 07:52 PM
