KDL-40z5500 SONY
  • abdekader
    • Jul 2014
    • 73
    • Turkey
    KDL-40z5500 SONY
    I have KDL-40z5500 SONY , the red led blinks 6 times what's the mean that, please? >>> what's the problem ?
    i can't find manual for this problem
    Electronic Engineer from Syria,Aleppo
  • matwan
    Sony XR-55X90J 5 blinks
    by matwan
    I have problem with SONY 55X90J. After several check status is as below;
    1. Running power board as stand alone:
    TCON_12V =~ 12.6V
    EVDD V On Max 24V= 19V.
    2.
    Running power board with TCON as stand alone:
    Effect as below, attched.
    3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
    "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
    Best regards....
    09-28-2025, 04:26 AM
  • GoodCapDude
    Sony XBR-75X940E intermittent 6 blinks error code
    by GoodCapDude
    Hi everyone. First post on Badcaps!
    I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
    09-20-2025, 06:07 AM
  • Nicktronic
    Sony XBR-65X850D 2 Red Blinks
    by Nicktronic
    I have the subject TV and it will work normally sometimes but suddenly go black and give the 2 red blinks blink code. When this happens, I check the power supply board voltages and all I have is the Standby 3.3V and BL_ERR 2.2V. When it's working normally, all power supply board voltages look normal and stable. I've checked the backlights with a tester and they all test good. I've also read that the 2 red blinks is a faulty power supply board, so could it be throwing up an erroneous BL_ERR?
    Any Sony experts out there that can help??...
    11-19-2023, 06:51 AM
  • x_orange90_x
    Sony KD-60X690E 6 Blinks, no image
    by x_orange90_x
    I just got this today and it has the infamous 6 blink code. I've read it's quite possibly bad backlights, and I intend to check them soon. However, I was just curious if the Sony logo should it's shouldn't be appearing briefly between powering on and the light starts flashing. I've read at least one other person had the logo flash quickly, but mine does not show anything at all, not even a flicker. The green light comes on and after about 5 seconds the red light flashes. So I'd expect in this 5 seconds to see the logo. This leads me to believe it could be a power supply issue.
    I...
    12-10-2024, 09:10 PM
  • dominik0801
    SONY KDL-43W755C | 5 blinks stand-by LED
    by dominik0801
    Hello guys.
    Today I got this TV for free, the friend included a "new" (used) TCON with it, since he told me, that doesn't work either.
    With the stock TCON, this TV turns on, stays on, but the screen only has 5 RED vertical lines on it, and that's it.
    Backlight stays on and is fine.
    With the "new" TCON, the TV turns on, shows SONY logo, some spinning circles, then the TV goes blank, and the stand-by LED is blinking 5 times, won't react to anything.
    I have read some forums, where it's been told that the part number is not always enough...
    12-18-2023, 11:40 AM
