TV issue
  • tech2014
    • Aug 2014
    • 807
    TV issue
    Has anyone ever encountered this problem? A friend of the family emailed me and told me this about her tv.
    the input mode keeps popping up and won't go away and when it's up can't use the remotes to turn tv on or off or volume but if we can get it to go away it works
    Sorry didn't get the brand and model number yet.
  • Glitcher
    • Mar 2013
    • 673
    • USa
    Re: TV issue
    I had a small 32" philips or magnavox lcd tv that did that. I did a firmware upgrade on it and it seem to have solved the problem i think.
      Re: TV issue
      I've encountered stuck buttons causing this issue in the past.
      • tech2014
        • Aug 2014
        • 807
        Re: TV issue
        thanks guys I will look into the button issue.
        • rounin
          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
          by rounin
          🛠 Original Issue
          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
          04-19-2025, 01:18 AM
        • ugamazing
          by ugamazing
          12-17-2024, 07:05 PM
        • elmark
          HP 15-cw1002ua strange keyboard issue
          by elmark
          HP Pavilion 15-CW1002UA
          S/N 5CD0251CBC
          P/N 7KE54EA
          Hello guys!
          I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
          It powers on OK and has no other issues except the following:
          • CAPS LOCK does not work at all
          • Fn button toggles Flight Mode
          • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
          • (with SHIFT pressed: 't%' and 'y^' respectively)
          I initially thought it was a keyboard malfunction (internal short, etc.),
          but when I press and hold...
          06-27-2025, 01:10 AM
        • Simone Vergani
          Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
          by Simone Vergani
          I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
          To assist with troubleshooting, I'm attaching two power circuit schematics:
          • Power
          03-05-2025, 02:25 PM
        • wizard13
          Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
          by wizard13
          I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
          I have checked the forum and the available documentation but could not find a solution specific to my issue.
          • Brand & Model: Dynabook Satellite Pro C50D-B-100
          • Part Number (P/N): PYU13E-00C00PFR
          • Serial Number (S/N): 22028896H
          • System Configuration (SC): A1PYU13E1127
          • Motherboard Model: IP3_ACN16_MB_V21_20211222A
          • Power Input: DC 19V –
          02-28-2025, 02:43 AM
