Pro Vision HQL320WR - Stuck on Stand By
  • electro76
    • Dec 2007
    • 22
    Hello Badcaps,
    I got this Pro-Vision 32" LCD with 'LG Panel' as it won't turn on anymore and they wanted to throw it away.
    The stand by led is on but strangely it's lit orange color as if both the red & green are on.
    Checked the voltages on power board - all show zero but
    they come back to life when 1 specific conn disconnected from the main DVI/VGA board (only needed to remove the cable marked with 'I' to see all voltages come back).
    The P106P connector pinout is: GND, +5V, ST_BY_5V, +9V, MAIN_ON, LVDS_ON, GND.
    Not sure but it seems that the main board does not send the on-off signal to power board or causing all voltages to drop to zero.
    I also noticed that half way insertion of P106P marked conn, the LED lights in red only (and not a bi-colored orange).
    When stand alone power board is connected to mains these 3 voltages do not exist:
    LVDS_5V
    MAIN_ON
    LVDS_ON
    All other voltages appear OK:
    +24V
    +3.3V
    +5V
    ST_BY_5V
    +9V
    +33V
    +15V
    Can you please advise schematic for this set and what to check next?
    I would suspect a main board issue but cannot debug without a diagram.
  • DXseekerMO
    Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
    by DXseekerMO
    Hello everyone!
    Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
    Symptoms:
    1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
    2) TV does not appear to turn on
    3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
    4) "Power on" terminal on Power Supply has 3.26v
    5) "A13V" terminals have 12.9v
    6) Stand-by test jumper on Power Supply has 12.9V
    7) Optical audio jack on Main Board illuminates
    8) With stand-by...
    06-09-2021, 12:19 AM
  • Stunt
    Hp Laptop Stuck on Hp protected by hp sure start screen
    by Stunt
    Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
    I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
    I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
    Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
    screen that's it and stuck there. I left it until the following day and i still...
    09-02-2025, 01:51 PM
  • Capacitorial
    Powersupply has all the voltages - Monitor still no power
    by Capacitorial
    Hello guys,
    I have a Philips 240B7QPJEB. The monitor seems completely dead.
    I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
    On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
    The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
    The weird thing is, that the Power LED is powered over the TCON board.
    On The TCON...
    12-28-2024, 02:12 PM
  • stormanimal83
    Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
    by stormanimal83
    Hey....
    Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
    my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
    01-18-2024, 02:15 PM
  • ekozeko333
    [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
    by ekozeko333
    I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
    🔥 The Problem Started After Suspected ESD/PD Fault
    I experienced a power issue or ESD event through a USB-C charger
    After that, the NX20P5090 power switch was visibly burned and was replaced
    Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
    🧠 What I’ve Done So Far
    Flashed...
    06-21-2025, 02:48 AM
