Panasonic TC-P55VT60 12 blinking red lights
  • jpars82
    • Aug 2014
    • 4
    Recently, my Panasonic plasma tv shut off on me and I'm getting the 12 blinking red lights. If I disconnect the power and reconnect it, it will work fine for about 15 minutes or so and then shut off again with the 12 blinks. From searching around a bit I've seen 2011 model tvs from Panasonic have the 12 blinks as meaning a bad A board. Is this correct for 2013 models as well?
    I'm not experienced with electronics and have never attempted a tv repair before, but my warranty was up a few weeks ago and I'm unsure how high the charges with be with a service center. I would like to consider fixing it myself if it's possible. Any help or advice is appreciated.
    Thanks,
    Josh
    Re: Panasonic TC-P55VT60 12 blinking red lights
    An intermittent 12 blink fault sounds quite likely to be an A board.
    Contact Panasonic. They have sometimes been known to allow for an extra month or two out of warranty.
    • jpars82
      • Aug 2014
      • 4
      Thanks. I will give Panasonic a call first and see if they're willing to fix it.
      • jpars82
        • Aug 2014
        • 4
        Well it is a no go with Panasonic. My purchase date was a year and 5 weeks ago so they're unwilling to cover it. I guess I will now try replacing the A board to see if that works.
        • cue45
          • Aug 2014
          I had the same problem with my panasonic TC-P65GT30 I had 12 blinks first take plug A11 from the A board and if the blinks go away and tv cuts off and on normal and then it is the speakers check the wire on the speaker to see if has bare wire which is causing a grd or sht either repair or repl if A Board still blinks after removing A11 repl Board
          • Andre Gilbert
            by Andre Gilbert
            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
            11-20-2024, 08:52 PM
          • bialag
            Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
            by bialag
            I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
            Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
            03-25-2025, 05:56 PM
          • Audeze
            Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
            by Audeze
            I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
            Does...
            10-06-2024, 08:54 PM
          • jm1234
            Panasonic plasma TX-P42ST50 - 6 blinks
            by jm1234
            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
            I checked that board for any obvious faults...
            05-22-2024, 06:59 AM
          • riparo
            Panasonic Oled 55EZ950E, no picture, red led blinking every 4 sec
            by riparo
            Hi everyone, I have a Panasonic OLED TV model 55EZ950E, as soon as I turn it on I don't have any image the LED goes from green to red LED blinking every 4 sec, I found the service manual suggests checking OLED PANEL, PB BOARD, T-CON connectors but it seems like everything ok, I didn't find any burns under the pb board
            I attach a link to download the service manual, thank you for anyone who can help me
            https://tel-spb.ru/download/?brand=P...0E_LA73.rar​
            01-11-2024, 12:35 PM
