Philips 42pfl6008s/12 red led comes on for a second and then goes away but 3.49v stay active
  • Malcolma172
    • Jul 2025
    • 8
    • Malta
    I was trying to repair my tv wich previously had a blinking red led 2 times and it kept going. After shorting the sdm the blinking led changed 5 slow blinks and 3 fast ones wich in the service manual meant error 53 / the fusion chip.
    After I heated the fusion chip with a hairdryer for 5 minutes it started working perfectly but after a day it stopped this time no led blinks even in sdm mode.
    After probing the psu I have 3.49v and for 1 second I have at least 2 12.3v lines active the fusion chip gets warm in that second the led turns on and then the 12v lines start losing power but the 3.49v stay active then nothing no blinks and reheating the fusion chip didn't work.
    Could it be something different or is it the fusion chip and it can't be repaired
    Motherboard 310430354945
    Psu 2722 171 90775
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4318
    • Italy - Milan
    CPU solder balls are outdated, needs reballing, eventually needs also resolder the nand flash and or the ram chips
    • Malcolma172
      • Jul 2025
      • 8
      • Malta
      Do you think the cpu is still good the first time I heated it with a hairdryer for 5minutes straight and it fixed it but when it stopped working again I tried it again and it didn't work. The first time I had an error code and the 12v lines where all active now the 12v lines deactivate.
      • lotas
        • Jan 2016
        • 4589
        • Russia
        If you heated it with a hair dryer without bottom heating, then most likely the board was warped, bent, deformation occurred, now the chip does not fit evenly to the surface, if so, then now even reballing will not help, only replacing the board.
          • 12151
          • U.S.
          It's also possible that the hairdryer didn't get it hot enough to do a good job.
            • 12151
            • U.S.
            It can be tricky, too much heat can kill/warp etc, too little and no damage just no or bad/temporary results. Check some of the trusted youtube videos on reflowing, some good ones will use liquid no clean flux and try to get it under the chip. Slowly bring up temp to melt the solder balls. It could be good to have a second pair of eyes to see when the solder melts. Some will hold a little pressure on the chip for a bit while it cools, some don't. Have seen the diy reflows last a long time with a fan solution blowing directly on (not sucking out) the heasink covering the chip.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4318
              • Italy - Milan
              Real hairdryer has made probably only a partial deoxy together with dilatation that momentarily fixed the gap, but at long distance also for dilatation more balls can have detached, i did not notice the word hairdryer, balls must melt so it is not enough, to be made at home needs at least a large aluminum plate put on a small stove, and also heated from top with a heat gun at least 300w, also flux paste under the chip, needs the "move" check on the chip, check if sourrounding chips / components are still in place, a missing one can have stopped some line to the 25q flash chip responsible of standby software, example a resistor to the DI / Do line..
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4318
                • Italy - Milan
                Have you got an oscilloscope? check 25q memory for data in/out.. you can try it also with a AMM or DMM maybe..
                • Malcolma172
                  • Jul 2025
                  • 8
                  • Malta
                  No I only have basic tools just a multimeter and a soldering iron
                  • Malcolma172
                    • Jul 2025
                    • 8
                    • Malta
                    I think I am going to throw it out I have been trying to repair it for a few days.
                    I might just try the hairdryer again before throwing it in the trash because I can't find a replacement motherboard online
                    • Malcolma172
                      • Jul 2025
                      • 8
                      • Malta
                      After heating it up again I have a solid red light no 12v. The fusion chip is the problem does anyone know if there are replacement motherboard available in cant find any.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4318
                        • Italy - Milan
                        replacemet boards are out of stock since many years.. there was an enterprise that sold for this chassis an alternative Android board.. search around.. use chassis model to search.. QFU2.1E.LA, if i remember
                        • Aliencomputres
                          • Aug 2019
                          • 208
                          • România
                          Psu 2722 171 90775
                          Exposing the chip to the temperature generated by the dryer for a long period of time can lead to its destruction.
                          • Malcolma172
                            • Jul 2025
                            • 8
                            • Malta
                            I had taken it to a repair shop they said it wasn't worth fixing so I tried repairing it and it lead me to the fusion chip so I did it as one last effort and the tv worked for a bit
                            • Malcolma172
                              • Jul 2025
                              • 8
                              • Malta
                              I have been seeing universal android boards is but the ones I have been seeing have their own psu and tv remote is there an android board made specifically for this tv I can't seem to find anything online
                                • 12151
                                • U.S.
                                I believe you are correct, it's only a philips and 42 inch, it's not worth the effort or expense, I would /recycle it.
