Tesla 40t319sf bios
  • b(p)lenky
    • Oct 2016
    • 6
    • croatia
    Tesla 40t319sf bios
    Hi, i have a problem with this tv,bios is dead,it has red standby light but wont turn on. mainboard is TP.MS3663S.PB781 and bios chip 25q64. i managed to read old bios file from 8-th attempt but when i write it to new chip it doesnt work,it wont turn on.
    I found bios for same motherboard but for different tv brands like vesta or artel and the tv works but the remote doesnt respond and i cant get a remote for that brands, not does any universal remote.
    Anyone has a dump for this tv??
    Tnx in advance
  • lotas
    • Jan 2016
    • 4696
    • Russia
    Post your native dump here, I'll take a look.
    • b(p)lenky
      • Oct 2016
      • 6
      • croatia
      Here...
      • b(p)lenky
        • Oct 2016
        • 6
        • croatia
        Any luck??
        • lotas
          • Jan 2016
          • 4696
          • Russia
          Your dump is badly damaged, I'll try to restore it, it takes time.
          Do you have a 40 panel diagonal? Write the exact model, it is on the nameplate of the buffer strips.
          And also, can you read the dump from the chip again (did you read the dump via a clothespin or did you unsolder the chip and use an adapter on the programmer?).
          • b(p)lenky
            • Oct 2016
            • 6
            • croatia
            Display model is LVF400CMDX E0006.
            Sorry i cant read it again,i tried multilpe times,it doesnt react
            • lotas
              • Jan 2016
              • 4696
              • Russia
              How do you read the dump? You unsoldered the chip from the board and read it through an adapter on the programmer or directly through a clamp. If the chip is not read, try heating it up. It doesn't work. Try cooling it with a freeze. Sometimes it helps. Clean its contacts well from flux....
              • b(p)lenky
                • Oct 2016
                • 6
                • croatia
                Iwe tried everything,i just doeasnt work,the chip is dead.i did unsolder it in first time to get this dump that i sent
                • macabook
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
                  by Vesko356
                  08-11-2023, 03:27 AM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                • zenius
                  by zenius
                  12-08-2024, 06:13 AM
                • Wahaz
                  by Wahaz
                  10-30-2023, 08:42 PM
