Hi everyone. I purchased a Samsung pn58b540s3fxza with sound but no pic. After getting it home I noticed there's a tiny crack in the screen. First question is will a plasma TV turn on and not throw an error code if the panels cracked? Second ?? Theres someone selling a pn58b650s1fxza for parts cheap here, are the panels the same? Is there a site to check or do I have to actually take the back off and check the sticker?
any site to check panel compatibility?
Re: any site to check panel compatibility?
1. It will almost never work with a crack. In the rare cases it does work, the picture will be severely compromised (see here: http://i.ebayimg.com/00/s/MTIwMFgxNj...kVk0/$_57.JPG#)
2. There is no direct way to check compatibility. The one thing you have going for you is the 5 series and 6 series are both Full HD panels. However there may be differences in the driver boards and control logic, which will mean they will have to be swapped with it. A right hassle! The best you can do is Google the TV model numbers to get pictures of the boards and confirm. At the very least I expect the sustain boards to be different. The PSU may be identical.
Personally, I would not bother swapping the panels over, as for such a large screen it will be a very complex job. I would fix the other TV and regard this one as a loss or sell it for parts.Last edited by tom66; 08-16-2014, 03:42 PM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
Well, that is probably not going to be fixable by swapping over parts unless the boards are compatible, as I mentioned this is probably not going to be the case unfortunately. You would have to do a diagnosis and repair of the fault.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Go to shopjimmy and type in your model. Then confirm the ymain is the same, so taking the back off and checking the parts would help. You'll see a couple of revisions but they are physically essentially the same.Hi everyone. I purchased a Samsung pn58b540s3fxza with sound but no pic. After getting it home I noticed there's a tiny crack in the screen. First question is will a plasma TV turn on and not throw an error code if the panels cracked? Second ?? Theres someone selling a pn58b650s1fxza for parts cheap here, are the panels the same? Is there a site to check or do I have to actually take the back off and check the sticker?
It lists
LJ92-01628A
panels
S58FH-YB03, S58FH-YD01
models
PN58B540S3FXZA
PN58B550T2FXZA
PN58B560T5FXZA
PN58B560T5FXZC 0002
PN58B560T5FXZC 0001
PN58B560T5FXZC K602
PN58B560T5FXZC K601
PN58B650S1FXZA
LJ92-01628C
panel S58FH-YB03
models
PN58B540S3FXZA
PN58B550T2FXZA
PN58B650S1FXZAComment
I did something similar a while back.
A 42 Sony monitor plasma with the LG 42V7 chassis and a Matsui with the same chassis....
Panel itself was much the same. However the Sony used a different PSU so it was impossible to mount the PSU as was intended.
I did jury-rig the set up in the Matsui and gave a perfect picture with the 'new' Sony LG V7 panel, but further than that Ive not mounted/made a mount for the PSU....
Thinking of cutting a section of the metalwork from the original panel, mounting the PSU on that as all the mounts will then line-up then fixing that onto the Sony V7 panel.....
Ive already removed the mounting-studs from the Sony PSU to the ally panel rear....
Time to get me angle-grinder out!
TELEFIX
PLEASE DO NOT EMAIL ME PRIVATELY FOR REPAIR ADVICE. QUESTIONS BELONG ON THE FORUM!Comment
by NolesFanI have a TV, ( example ) Sony XBR-75X80G that the LED panel is cracked, does anyone know if we can take the LED panel from a ( example ) Sony XBR-75X80H and plug it in and it will work? Or if the panel measurements is not exact, can we take the internals of the cracked panel 80G TV and mount into the good panel 80H TV? Thank you06-23-2025, 09:19 AM
by nobbnobb1Hello,
I have an HP Elitebook G8 845 with the base 14" 250 nit LCD screen which looks terrible. I believe the base unit is a B140HAN04.6 (but not 100% sure). From looking at some part interchange numbers, I believe this is the 400 nit upgraded panel which came as an option (not 100% sure...just based off an Aliexpress listing):
B140HAN05.3 https://www.panelook.com/B140HAN05.3...iew_42334.html
Then looking at the same family of panels, this unit appears to be a version with better specs:
B140HAN05.9 https://www.panelook.c...02-24-2024, 04:45 PM -
by triplefourTV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
tcon is built into mainboard.
Only one cable goes to panel boards.
there is a cable from one panel board to the other that links them.
cost cutting measure that results in us having harder time to diagnose.
removing the link to the second panel board allows TV to stay on with stable backlight but no image.
used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board.... -
I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....01-13-2024, 01:57 PM -
I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
...11 Photos - Loading...
