vestel 17pw26-4 weired fault,help
  • promo7uk
    • Aug 2014
    • 31
    • uk
    im a tv engineer and i cannot for the life of me find this sodding fault.
    i have a vestel 17pw26-4 from a jvc 32" tv,
    i have replaced q813 , q814 + fan 7711 chips. now psu works but,, drop a load onto it voltages drop.. all of them 3.3v 12v 24v , every single voltage slowley drops.. anyone had same problem and manage to fix please let me know for furture ref as its piddling me off, cheers
  • senndogg
    • Dec 2011
    • 383
    • Albania
    Re: vestel 17pw26-4 weired fault,help
    does the standby voltage drop too? can you check the voltage in the 22/33uf 35/50V small cap in the primary side?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      I hate vestel boards especially the 17pw20-26 models when ever you fix one problem another occurs, its probably cheaper to replace the board (parts and time wise). I have seen the output voltage drop due to bad pfc try checking the voltage on the main filter capacitor should be around 385v while on if its lower than that check the pfc. I had a 17pw26-4 that had voltage dropping issues on the output and it turned out to be the pfc the main cap was only getting 330v dc it turned out to be the pfc, I ordered parts from http://sparedparts.com/parts/manufac...ory/vestel/P29
      • Jaime Morillo
        Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
        by Jaime Morillo
        Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
        The TV was stuck on the logo and I couldn't access the update menu.
        I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
        The image result was good, but the image is inverted.
        The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
        Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
        08-18-2025, 11:38 AM
      • France_53
        Vestel tv, how to flip the image?
        by France_53
        Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
        05-12-2024, 05:22 AM
      • FlailingEngineer
        Help with Bush Tv (Vestel 17mb95m Mainboard)
        by FlailingEngineer
        Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
        Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
        05-31-2023, 06:52 AM
      • lberkani
        Request: USB firmware for Toshiba 65UL2163DG (Vestel 17MB180E) - panel VES650QNTX-N2-N42
        by lberkani
        I’m looking for the correct firmware for my Toshiba 65UL2163DG TV.
        The mainboard is Vestel 17MB180E, and my panel is VES650QNTX-N2-N42.
        The board I received is flashed for VES650QNDB_N41 and shows double “No signal”.
        I need the correct USB update package (upgrade_mb180.zip / upgrade.bin) for:
        - Toshiba 65UL2163DG
        - Vestel 17MB180E mainboard
        - Panel VES650QNTX-N2-N42
        - Version V1.28.100.0 if available
        If anyone has the file, please share a download link (WeTransfer, MEGA, Google Drive) and include version.txt...
        11-11-2025, 12:37 PM
      • hazi12
        Vestel main board 17MB140TC
        by hazi12
        Hello, board 17MB140TC, I need to change the remote control in Vestel tool box 1.1. The original is there
        Rc48xx_2D and I want to install TOSHIBA-Rc481xx, but the program says that a maximum of 9 characters can be entered. I only entered Rc481xx and the program does not accept the driver I have in the original. Does anyone know how to do this? Other Vestel codes work.
        I can send a dump....
        10-01-2025, 01:28 PM
