Panasonic TH-50PZ800U - 10 Blinks
  • nwcs
    • Dec 2015
    • 311
    • usa
    Re: Panasonic TH-50PZ800U - 10 Blinks
    I should have known he damage it when he told me he had replaced the buffers because of the 10 blink code. I wouldn't have repaired it if I had know. But good thing is he left it with me and I can make some money off of it.
    • HenryJ
      • Oct 2006
      • 54
      Originally posted by nwcs
      I think I am going to pull the parts and sell them. At least I know they are working.
      Front Glass in good shape?
      • nwcs
        • Dec 2015
        • 311
        • usa
        Yes, in great shape.
        • HenryJ
          • Oct 2006
          • 54
          Nice so, What's this going to cost to ship I'm tired of looking at crack in mine that is if your willing to do so.
          NJ business 08831
          • nwcs
            • Dec 2015
            • 311
            • usa
            I would gladly ship it to you. I do not know shipping cost. What is your mailing address and I will check.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              #26
              NJ business 08831
              Yeah but you realize the panel is failed/damaged right ?
              • nwcs
                • Dec 2015
                • 311
                • usa
                #27
                That's true the panel is bad.
                • HenryJ
                  • Oct 2006
                  • 54
                  #28
                  Panel not needed front glass in front on panel.
                  • HenryJ
                    • Oct 2006
                    • 54
                    #29
                    Check your PM's
                    • Andre Gilbert
                      by Andre Gilbert
                      11-20-2024, 08:52 PM
                    • jm1234
                      Panasonic plasma TX-P42ST50 - 6 blinks
                      by jm1234
                      anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                      It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                      I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                      I checked that board for any obvious faults...
                      05-22-2024, 06:59 AM
                    • Alicat
                      Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                      by Alicat
                      Stopped by this site trying to fix my parents Panasonic Plasma TV.
                      Model number is TH-50PZ85U
                      Power comes on and the red power light stays on solid.
                      Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                      I also hear a few clicks.
                      I also think my parents said there was a thunderstorm and the TV failed after that.
                      Section 6 in the service manual talks about power and no screen,...
                      10-30-2024, 10:09 AM
                    • CrewmanRedShirt
                      Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                      by CrewmanRedShirt
                      Hello all,
                      As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                      07-13-2024, 11:02 AM
                    • nobbnobb1
                      Panasonic TC-P50U50 Powers Off - 8 blinks
                      by nobbnobb1
                      I have a Panasonic TC-P50U50 plasma TV which powers on briefly, then powers off and flashes the power light with 8 blinks. This TV is infamous for this, of which the suggestion that the SS board has failed due to loose grounding screws and requires a replacement of the following components on the SS board:
                      2x DG302 (Q16051)
                      2x RF2001 (D16041)
                      2x 5.6 ohm SMD resistor
                      1x BD8694 IC
                      I have already gone ahead and replaced these components, as well as cleaning off the ground connections on the SS board as well as the associated...
                      03-21-2023, 08:33 PM
