Vizio XVT3D474SV: power but no video, suspected t-con failure
  • digant
    • Dec 2014
    • US
    Re: Vizio XVT3D474SV: power but no video, suspected t-con failure
    I also own Vizio XVT3D474SV and it is havibng the same problem described above. I changed the Main Baord but the problem persist...so now i am left with two other options - replace power board or replace t-con board.
    I was curious to know if you could finally isolate the faulty part and make your TV set work; if so, which part was faulty.
    Sincerely,
    Digant
    • unlimitedbacon
      • Aug 2014
      • 11
      • US
      Yes. I ended up replacing the T-Con board and it works beautifully now. They're tough to find though, probably because this is a common issue. Keep an eye on eBay. They pop up every now and then.
      • digant
        • Dec 2014
        • US
        Hello Unlimitedbacon,
        Tons of thanks for quick response.
        It is a huge help!
        Wish you happy holidays and 2015!
        Regards,
        Digant
        • Arc_Light
          • Feb 2015
          Hello Digant and Ulimited bacon and anyone that could help out.
          I have the Vizio XVT3D474SV as well. Just picked it up as a project tv and not going to far getting it working. I probably spent too much trying to fix it already. Boards are very hard to come by and there is probably a good chance they don't work (maybe my replacements) or will fail.
          So far I replaced the TCon and main and all I get is backlight. I first thought the tcon but no improvement so I went with the main and still nothing. No audio click ad well like one might hear when the tv comes on and from the white vizio light to the backlight showing it is about eight seconds. I have the lay of the land so far with voltage checks and I can feel heat on the main board heat sink but no heat from the tcon heat sink. I have voltage across the tcon fuse but I read about mosfet voltage checks but can anyone show me a picture of the location. Any other information on troubleshooting parts and what people have found would be helpful. I an too cheap to buy a new one. Thanks
          • howardc64
            Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
            by howardc64
            Problem
            Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
            Model & Board Pics
            Conflicting Spec
            Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
            https://www.shopjimmy.com/vizio-gj-2k1...
            10-10-2024, 01:16 PM
          • Fly_Among_Stars
            VIZIO E70-E3 Half picture with half TCON
            by Fly_Among_Stars
            I have a VIZIO E70-E3.
            Symptoms: Black screen, no picture, but LED backlights are working.
            I probed the power board and voltages are as listed on the board.
            Main board appears fine, too.
            I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
            There are two separate ribbon cables feeding the LCD.
            If both are connected, the screen is black.
            If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
            04-24-2023, 08:20 PM
          • kca
            by kca
            Hello all ~
            08-31-2025, 06:38 AM
          • x_orange90_x
            TCL 50S535 bad tcon or panel issue?
            by x_orange90_x
            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
            03-29-2025, 11:02 PM
          • Nr4ps
            Vizio DPS-167DP-1 failure
            by Nr4ps
            I'm trying to troubleshoot a DPS-167DP-1 A power supply board from a Vizio M552i-B2 tv. The tv would no longer turn on, and I found the usual melting on IC901, with D950B and ZD909 shorted and R915 open. Sounds like this is a pretty common failure, so I replaced all four components expecting it to be an easy fix but it's still not working.
            I checked D801 and it's fine. I get about 170V DC across the main filter capacitor C800A. I'm not getting any voltage on the 5V standby pins in connector CN101, nor any voltage on the VCC pin of IC901, which is presumably why it's not working --...
            01-26-2024, 03:53 PM
