Samsung LN40A530 No Standby Voltage
  • tvguy12012012120
    by tvguy12012012120
    02-07-2025, 05:13 PM
  • x_orange90_x
    Samsung UN55KU6300F no standby voltage
    by x_orange90_x
    I have no standby indicator light and no light on the optical port. I checked the standby voltage on the two mosfets in the top left and they both read 30mV. I checked the fuse and it has continuity. I also checked the voltage on the two large 450v caps they both read 153v. All of these voltages are the same with and without the main board connected as well as with backlights connected/disconnected.
    Nothing looks obvious like a burned ceramic disc cap or bulged electrolytic. No burned resistors, diodes, or anything like that....
    05-21-2025, 09:59 PM
    09-07-2024, 05:50 AM
  • Sportline
    Samsung LE32S81B - missing standby voltage
    by Sportline
    Good day, instead of Q0165R I mistakenly put 24C256 (don't ask me how) and made a short circuit. After I put Q0165R I don't have stand by voltage again. There is no voltage on the cold side. I found the schematic.
    I checked a few things but didn't find anything. When I checked the DB802 diode, it showed a short circuit, but when I unsoldered one leg, it looked fine, and I still have a short circuit on its contacts. On the other side of the board, I have DZB801 also shorted, but it is SOT23, so I didn't remove it, do you think it could be connected to it? Could there be some protection...
    03-10-2023, 06:38 AM
  • Bad_IC
    Philips TV 37pfl5604h/12 no standby voltage
    by Bad_IC
    I have a problem with this TV, the standby voltage is not present. I have checked the components around the IC fsq510's area and they seem to work, also replaced this IC but the problem persists.
    These are the voltages in some pins of IC fsq510:
    Vcc=18v
    D=320v
    Vstr=154v
    Unfortunately, I couldn't find the schematic
    What else could I check?
    Is it possible to provide standby voltage from an external source to allow the TV to turn on?
    Thank you​...
    11-08-2024, 01:07 PM
