hi i need bios dump without pass or fix this
					HIKVISION DS-7208HGHI-K1 80389 Rev 1.4 BIOS DUMP ...
			by AhariHi all,
 I...-
			by mkdjDear all,
 I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
							Channel: BIOS Requests ONLY!
			by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
 Suspected Cause:
 Troubleshooting Attempts:
			Hello engineers 😀,
 🔧 Device Info:
 - Model: HP 15-da2007ne
 - Product Number: 8XF55EA#ABV
 - Serial Number: CND0338P0D
 - CPU: Intel Celeron N4000
 💀 Problem:😅
 - Device shows “Administrator Password”...2 Photos-
			by CityminHi all,
 S/N : 5RNK9FFT70...-
- Loading...
