Hi folks, I have a problem with my Samsung (Model S42AX-YB04). The TV turn on automatically and a relay makes a click noise every 15-20 seconds but no audio/video. No capacitors are blown in the power supply, and voltages in the power supply, X-Main e Y-Main seems to be OK. I've even tested the T-CON board by shorting the pins 3-4 and disconnecting the LVDS cable, and I see the test color pattern, that seems (i think) that the panel and T-CON board works properly.
Now, my last try is to short the 5-6 pins on the eeprom located on the mainboard in order to reset it, and now the TV remain in standby, but if I try to power on with the remote the IR responds, but the tv won't turn on.
Any suggestion?
Thanks in advance (and sorry for my bad english )
Any suggestion?
