RTRU6528-C-CA
  • x2006nzl
    • Apr 2013
    • 11
    • canada
    RTRU6528-C-CA
    I have a RTRU6528-C-CA the leds went i took it apart and ordered the same nu.bers they fit and the holes are right but the connectors a bit different can I cut the connector and solder the positive to the positive and negative to the negative on the led strip for it to work thanks
  • Diah
    • Feb 2013
    • 6460
    just be caution on the LEDs self if they are installed on the strips in opposite way too, so check and compare with yours old one, if they are correct installed + - as the old then ok
    • x2006nzl
      • Apr 2013
      • 11
      • canada
      Thanks for the reply so I can just cut the connectors off and solder the wires to the + and - on the led strips for the tv thanks
      • x2006nzl
        • Apr 2013
        • 11
        • canada
        And is there something i can put over it once it's soldered thanks
        • lotas
          • Jan 2016
          • 4785
          • Russia
          Solder to these pads, observing the polarity and there is no need to add anything.
          • x2006nzl
            • Apr 2013
            • 11
            • canada
            Also with this tv when I took it apart the reflective paper was taped/glued so most of it ripped so I took off all the pieces and bought a reflective paper, can I overlap the pieces as the roll isn't wide enough so I have to piece it together and should I use double sided tape or tape and will it effect the screen? Thanks
            • x2006nzl
              • Apr 2013
              • 11
              • canada
              Does it matter what tape and how i tape it?
              thanks
              • brispuss
                Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
                by brispuss
                Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
                Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
                I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
                12-28-2022, 02:58 AM
              • Pipolups
                Corsair K70 LUX RGB dying LEDs
                by Pipolups
                Hi there !
                I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                10-08-2024, 11:58 AM
              • howardc64
                by howardc64
                Problem
                08-04-2024, 10:36 PM
              • acedogblast
                by acedogblast
                11-02-2024, 05:13 PM
                KDMPower MIPC MI-X8775CD [PCB WF-C rev:E]
                by momaka
                Remember that cheap $15 PSU that dmill89 posted a while back here?
                https://www.badcaps.net/forum/showthread.php?t=72229
                So I was randomly browsing on eBay (as always) and saw a listing for supposedly the same “775 Watt” PSU with starting bid at $1. Description stated “for part or repair”, with the owner/seller mentioning the PSU had blown/shorted. Surely I could spend a few $$ more and get the same PSU as dmill89 right from Amazon brand new and (probably) working… but where is the fun in that?!
                So I got this one instead...
                11-17-2020, 12:03 AM
