Visio VU42L FHDTV10A voltage to main board?
  • CTMillard
    • Jul 2014
    All,
    I have a Visio tv that powers on, with backlight, but no picture or sound and can't turn off with remote or power button. I've seen countless posts and videos pointing to bad voltage regulators. But what has me puzzled is that on the 2 fuses where the power comes onto the main board, I get a reading of 19.25 and 8 volts. Everything I've seen indicates it should be 12 and 5. As a result, the readings I'm getting on the voltage regulators is off of what others are posting. Could 19.25/8 be correct? Should I be looking at the power supply board first?
    Troubleshooting electronics is new to me. I'm reading those numbers off both the fuses and the ribbon cable coming from the power supply board. I've got neg attached to the case frame.
    Any pointers are appreciated.
    Thanks.
    Terry
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: Visio VU42L FHDTV10A voltage to main board?
    Think you got lost in the many other posts...Don't be afraid to "bump" up your post..
    Reading this I would say your meter is suspect to being faulty,maybe try to measure a 9 volt battery with it and see what is gives you? New battery would be best..
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • JDC
      by JDC
      ONN 100012588
      Long answer:
      07-15-2022, 07:39 AM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • cheeky2
      by cheeky2
      05-25-2024, 03:27 AM
