SAMSUNG UE55TU7002KXXH rebooting
This topic has been answered.
  • unimatrix93
    • Oct 2021
    • 360
    • Magyarország
    Originally posted by lotas
    The marking is not visible in the photo, is it DIO2072?
    Yes it is.
    • lotas
      • Jan 2016
      • 4801
      • Russia
      There is no pinout in the datasheet, so search for "RRIO 10MHz Amplifier"
      • unimatrix93
        • Oct 2021
        • 360
        • Magyarország
        Is any of these are sufficient replacement?
        https://eu.mouser.com/c/semiconducto...%20min=2.4%20V
        • lotas
          • Jan 2016
          • 4801
          • Russia
          The link doesn't open for me...
          Look at these options
          COS722, TLV9062​
          • unimatrix93
            • Oct 2021
            • 360
            • Magyarország
            COS722, TLV9062​
            I found this one based on the TLV9062 at my local distributor.
            • bohaboha
              • Nov 2012
              • 1017
              • sweden
              #26
              to be continued ???? no next episode fren?
              • unimatrix93
                • Oct 2021
                • 360
                • Magyarország
                #27
                I ordered a new mainboard for a decent price and it is working perfectly. I also ordered the IC which Iotas recommended to fix up my faulty board.
                • KYBOSH
                  • Oct 2011
                  • 581
                  • Unknown
                  #28
                  Did you use the ICs to fix the board and get it working again?
                  If not, then those might not be the issue/solution.
                  • unimatrix93
                    • Oct 2021
                    • 360
                    • Magyarország
                    #29
                    I'm did not fix up the board yet, the new board works perfectly in the TV.
                    The issue with my previous board is the IC and the burned resistor next to it.
                      09-07-2024, 05:50 AM
                    • badboyzzz
                      Samsung UE50AU8072 all time rebooting, backlight ok. Maybe mainboard faulty?
                      by badboyzzz
                      The motherboard initially receives voltage for VGH, but it constantly reboots. When I remove the flex cable at the bottom, I hear normal sound, but there is no image on the screen and it is black on both sides. This time there is no voltage on VGH.
                      03-25-2025, 10:48 AM
                    • plytek
                      Samsung QE50Q60TA rebooting
                      by plytek
                      Hi all.
                      I'm trying to fix my Samsung QE50Q60TA TV.
                      IT's rebooting every few seconds.
                      I have done some tests and it looks like it stops rebooting when I tape pin 46 (I thinks it's FB_1) on the ribbon tape that connects two boards atteched to screen, but nothing is visible, just backlight is solid and I can hear sound. Taping over other pins doesn't work.
                      Have also soldered two pins on the motherboard to check if I can get an image on the rights side of the tv, but it keeps rebooting.
                      Can anyone suggest what I can test and do to get it working again please?...
                      02-08-2025, 06:02 AM
                    • stylishconsultant
                      un60j620dafxza - Samsung No Display Problem
                      by stylishconsultant
                      Hi All,
                      Need help.
                      I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                      So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                      problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                      might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                      09-04-2024, 03:26 AM
                    • Henke
                      Samsung TV HG46EB690QB No picture, only backlight when disconnected mainboard
                      by Henke
                      I came across a Samsung tv that does not seem to start up. When i plug it in nothing happens except that the red led turns on. But when i disconnect the mainboard, the backlight turns on and immediately turns back off when i connect the mb again.
                      I have tried to disconnect one, none and both cable(s) from the Tcon to the screen but it makes no differens. The PSU seems to work, but when the mb is connected one of the 5V cycles high and low.
                      Anyone with inputs?...
                      10-27-2022, 01:01 PM
