SAMSUNG UE55TU7002KXXH rebooting
This topic has been answered.
  • unimatrix93
    • Oct 2021
    • 360
    • Magyarország
    Hello everyone, I'm working on a Samsung TV that constantly rebooting.
    MB/PSU unit: BN9654185QE
    It loads up to the main menu then as soon as the backlight goes brighter it reboots.
    First I suspected the LCD panel, so a disconnected the LCD display from the mainboard but did the same thing.
    Then I removed the backlight connector which only delayed the bootloop by a minute maybe, I know it because I test it with the remote, it does gives the menu sounds a bit longer.
    Also I have to note, that the MB/PSU combo gives out a very noticible chirping noise like it's trying to start up.
    So even with the BL and LCD connector removed I can still hear the boot sound every 10-15 sec or so. So it's still rebooting with the disconnected.
    I guess it's a mainboard issue, is there anything I should check before replacing the MB?
    Thank you in advance.
  • Answer selected by unimatrix93 at 04-28-2025, 01:26 AM.
    lotas
    • Jan 2016
    • 4802
    • Russia
    The link doesn't open for me...
    Look at these options
    COS722, TLV9062​
    • unimatrix93
      • Oct 2021
      • 360
      • Magyarország
      So I did some measurements on the mainboard and noticed that I have a low resistance to ground (38ohm) on L88.
      The test point is marked BV097_PW2.
      I measure 0.90V on it during startup.
      The Ic next to it is a A0Z2255LQI DC/DC buck regulator and the inductor is connected to the LX pins of it.
      The IC has 12V VCC, which is supplied properly.
      Is this working properly or something is off?
      • lotas
        • Jan 2016
        • 4802
        • Russia
        Everything is correct, low resistance and low voltage is the power supply for the SoC (processor) core.
        • unimatrix93
          • Oct 2021
          • 360
          • Magyarország
          Ah so this is the power supply of the SoC. Now it makes sense.
          Any idea what could cause this issue?
          I measuring fluctuating voltages on the backlight.
          The board specifies 112V for 55' model like mine, but I measure 123V on it while its working and when it flashes and shuts down, I measure 80V then it quickly climbs up to 150V, then goes back to 123V while working again for a couple of seconds.
          • lotas
            • Jan 2016
            • 4802
            • Russia
            With the panel disconnected, you need to put a jumper, check these electrolytes...
            • unimatrix93
              • Oct 2021
              • 360
              • Magyarország
              I did some measurements based on the photo you made.
              I also made the jumper where you showed.
              Since my board looks different, I don't know where is the middle capacitor is on my board.
              • lotas
                • Jan 2016
                • 4802
                • Russia
                Then you don't need to look for the middle capacitor, since the boards are different, check the ones you have and what is the voltage on the power capacitor (PFC) in standby mode and in operating mode?
                • unimatrix93
                  • Oct 2021
                  • 360
                  • Magyarország
                  393V on both standby and operating mode.
                  CX8015 - 0v
                  CX8025 -0V
                  CP8015 275V
                  CM816 - 10.43V
                  CM813 - 20V
                  CM862 - 218V
                  CM853 - 12V
                  C9105 - 13V
                  C9101C - 197V
                  Last edited by unimatrix93; 04-10-2025, 08:42 AM. Reason: Added more measurements and photo of board
                  • lotas
                    • Jan 2016
                    • 4802
                    • Russia
                    So your PFC is working, check those capacitors for capacity and esr, with a jumper and the panel disconnected, how does the TV behave?
                    Have you checked the HDMI, USB, and LAN ports for low or short circuits on the signal lines?​
                    • unimatrix93
                      • Oct 2021
                      • 360
                      • Magyarország
                      I proceed to check the capacity (I don't have an ESR meter at hand sadly).
                      With the jumper on and the panel disconnected, the backlight stayed on for a long 2 minutes, at high brigthness. The tv responded to my remote commands, bleeping with menu sounds, then it went into restarting again. The difference is that the backlight had much higher brightness and it the tv were stable for 2 minutes instead of a few seconds.
                      Also, no short on the signal lines you mentioned.
                      • lotas
                        • Jan 2016
                        • 4802
                        • Russia
                        I think you have over-powered the backlight, check...
                        • unimatrix93
                          • Oct 2021
                          • 360
                          • Magyarország
                          Yes, you are right, I measure 170-200V on the discharge pins while the backlight is trying to stabilise.
                          Also I found something suspicious:
                          This small ceramic cap is next to the IC marked DI02072 which is right next to the backlight connector.
                          • unimatrix93
                            • Oct 2021
                            • 360
                            • Magyarország
                            I found the schematic of the IC.
                            Also turned out that the burned component is a resistor. I removed it from the circuit and I measure low resistance (53ohm) to ground on all of the non-GND pins of the IC.
                            Could this be the issue?
                            • lotas
                              • Jan 2016
                              • 4802
                              • Russia
                              Where is it located, in the backlight chain? You can take a look at a high-quality photo.
                              • unimatrix93
                                • Oct 2021
                                • 360
                                • Magyarország
                                As far as I can see, it's part of the backlight. I desoldered the IC to measure it's pins outside of the circuit and indeed the GND leg has 56ohm resistance to all other leg on it.
                                • lotas
                                  • Jan 2016
                                  • 4802
                                  • Russia
                                  Replace it. It also relates to backlight adjustment... But which resistor burned out, what should its resistance be?
                                  • unimatrix93
                                    • Oct 2021
                                    • 360
                                    • Magyarország
                                    R170, the one missing between the cap and the resistor.
                                    I can measure 140kohm on it, but since it let out magick smoke, the resistance of it might changed.
                                    I couldn't find the exact IC on any supplier sadly, maybe using something else with similar attributes could work?
                                    • lotas
                                      • Jan 2016
                                      • 4802
                                      • Russia
                                      You can take a high-quality photo of this microcircuit.
                                      • unimatrix93
                                        • Oct 2021
                                        • 360
                                        • Magyarország
                                        I hope this clear enough.
                                        • lotas
                                          • Jan 2016
                                          • 4802
                                          • Russia
                                          The marking is not visible in the photo, is it DIO2072?
                                            09-07-2024, 05:50 AM
                                          • badboyzzz
                                            Samsung UE50AU8072 all time rebooting, backlight ok. Maybe mainboard faulty?
                                            by badboyzzz
                                            The motherboard initially receives voltage for VGH, but it constantly reboots. When I remove the flex cable at the bottom, I hear normal sound, but there is no image on the screen and it is black on both sides. This time there is no voltage on VGH.
                                            03-25-2025, 10:48 AM
                                          • plytek
                                            Samsung QE50Q60TA rebooting
                                            by plytek
                                            Hi all.
                                            I'm trying to fix my Samsung QE50Q60TA TV.
                                            IT's rebooting every few seconds.
                                            I have done some tests and it looks like it stops rebooting when I tape pin 46 (I thinks it's FB_1) on the ribbon tape that connects two boards atteched to screen, but nothing is visible, just backlight is solid and I can hear sound. Taping over other pins doesn't work.
                                            Have also soldered two pins on the motherboard to check if I can get an image on the rights side of the tv, but it keeps rebooting.
                                            Can anyone suggest what I can test and do to get it working again please?...
                                            02-08-2025, 06:02 AM
                                          • stylishconsultant
                                            un60j620dafxza - Samsung No Display Problem
                                            by stylishconsultant
                                            Hi All,
                                            Need help.
                                            I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                            So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                            problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                            might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                            09-04-2024, 03:26 AM
                                          • Henke
                                            Samsung TV HG46EB690QB No picture, only backlight when disconnected mainboard
                                            by Henke
                                            I came across a Samsung tv that does not seem to start up. When i plug it in nothing happens except that the red led turns on. But when i disconnect the mainboard, the backlight turns on and immediately turns back off when i connect the mb again.
                                            I have tried to disconnect one, none and both cable(s) from the Tcon to the screen but it makes no differens. The PSU seems to work, but when the mb is connected one of the 5V cycles high and low.
                                            Anyone with inputs?...
                                            10-27-2022, 01:01 PM
