Vizio replacement boards Suffix differences
  • MisterD
    • Oct 2012
    • 668
    Does anyone know what the suffix means and if it matters on Vizio LCD TV Replacement boards? such as (5C) (5D) (X2) ??? my original has (5C) if I buy a replacement with same part number but a different suffix, will it still work?
    I see a board on ebay that has a yellow sticker with the part number, it appears to have a white sticker under that, and then some small round inspection stickers that are not normally there, maybe it was a warranty repair board, I don't know.
    Anyone have any comments on this? It will be appreciated.
    Thanks.
  • ugamazing
    by ugamazing
    12-17-2024, 07:05 PM
  • bstewara
    Vizio P659-G1 Screen Removal / Backlight Replacement
    by bstewara
    Hi All,
    Has anyone had the experience of replacing backights on the “P” series Vizio tv?
    Model number P659-G1
    This type tv has a very small bezel holding the screen in and I’m not sure how the bezel/screen is assembled. ( I’m hoping the screen is not epoxied to the frame)
    Before I attempt this I thought maybe someone on this forum has performed this backlight replacement procedure.
    Thanks in advance...
    09-26-2022, 10:40 AM
  • giddyupngo
    Backlight replacement mess, Vizio V505-G9
    by giddyupngo
    Hello, I would appreciate your expertise on this. I have about 5 years experience with copier repair, so I have done a lot of board and component replacement. This is the first LCD TV I tried to repair, and it really humbled me. The issue was that on power on the TV power light would go on and then fade out seconds later, and there was no image at all, screen stayed black.
    I thought this meant there was a power board problem, not realizing that the power light fading out was by design, probably so the light would not distract the TV watcher. This is not my TV, so I wasn't familiar...
    02-09-2023, 09:14 PM
  • ugamazing
    Apple M1 Boards & Exclamatory Error?
    by ugamazing
    We've now created a stack of 10 boards that have the same issue, which we suspect to be CPU-related. The issue is very simple--the board will not boot to anything, only showing the exclamatory sign inside a circle. No amount of DFU/restore, wipe/erase, etc, will resolve the issue. No boards have physical damage. We went ahead and replaced the SSD nands on two boards (one 02020, one 02016) and the issue remained exactly the same. We are considering replacing the CPU on one of the boards using a locked CPU, just so we can see if it resolves the issue.
    Has anyone else run into this...
    02-20-2025, 09:24 AM
