Samsung UE65MU6102KXXXH not work
  • Alex Corps
    • Mar 2025
    • 25
    • France
    Hi, I bought another clothespin, as soon as I receive it, I'll try another dump.
    • Alex Corps
      • Mar 2025
      • 25
      • France
      Hello, I received my new clothespin, which seems to be of better quality.
      So I did a first dump with Asprogrammer. If that doesn't work, I can do another dump with another application if you can advise me. Thank you.​
      • lotas
        • Jan 2016
        • 4854
        • Russia
        Try it, don't forget to set and write down the status registers (0x88, 0x42) after recording the corrected dump, it's better to do it in the program "NeoProgrammer V2.2.0.10"
        • Alex Corps
          • Mar 2025
          • 25
          • France
          Thanks for the dump, but I don't know how to do it for the status registers, so first I erase and write your dump in 25q40, but then how do I do it for the two status registers?
          • lotas
            • Jan 2016
            • 4854
            • Russia
            https://www.badcaps.net/forum/troubl...p-ic1604-25q40
            https://www.badcaps.net/forum/troubl...ainboard-issue
            Read this topic, I have described in it many, many times how to do everything correctly.Click image for larger version
            • Alex Corps
              • Mar 2025
              • 25
              • France
              #26
              ok, thanks for all this info, I'll try to figure it out, I'm not too comfortable with programming.
              • Alex Corps
                • Mar 2025
                • 25
                • France
                #27
                Do I have to do the reprogramming and the status registers at the same time? Or flash with the fix dump and then do the manipulation for the status registers?
                • lotas
                  • Jan 2016
                  • 4854
                  • Russia
                  #28
                  Programming instructions with the AsProgrammer program.
                  In the program:
                  1. Click "Detect Chip" and select W25Q40CL and "Select IC".
                  2. Click "Unprotect".
                  3. Click "Clear IC" and "Yes".
                  4. Click "Open File" and select your corrected dump.
                  5. Press "Program IC" and "Yes".
                  6. Click "Verify IC".
                  7. Press the down arrow to the right of "Unprotect" and select "SREG Edit", put a check mark on SRP0, BP1, CMP, QE (S3, S7, S9, S14) and press "Write" and "Yes"
                  7. Close the program. Ready.
                  • Alex Corps
                    • Mar 2025
                    • 25
                    • France
                    #29
                    Thank you very much for the very nice detailed procedure. I'll come back soon to let you know if it's ok.
                    • Diah
                      • Feb 2013
                      • 6560
                      he have Power On signal if the SPI defect !!! he used another repaired dump from here ( this why i hate one threat be more post from other users issue ) .. let me see when he show us working TV Photo.
                      • Alex Corps
                        • Mar 2025
                        • 25
                        • France
                        #31
                        I have nothing to lose, the TV won't start at all, I'll try it, we'll see.
                        • Alex Corps
                          • Mar 2025
                          • 25
                          • France
                          #32
                          Hi, when I want to write the status registers I don't have the same thing as in your image at all. QE is not highlighted so I can't check it and other values ​​are not present.
                          • Alex Corps
                            • Mar 2025
                            • 25
                            • France
                            #33
                            once checked
                            • lotas
                              • Jan 2016
                              • 4854
                              • Russia
                              #34
                              You need to remove the "locked" checkboxes.
                              • lotas
                                • Jan 2016
                                • 4854
                                • Russia
                                #35
                                I asked you to use NeoProgrammer
                                • Alex Corps
                                  • Mar 2025
                                  • 25
                                  • France
                                  #36
                                  not write and not (S3, S7, S9, S14)
                                  • Alex Corps
                                    • Mar 2025
                                    • 25
                                    • France
                                    #37
                                    It seems to be working, I got the red light back. It responds well to the remote.
                                    I'll ask my colleague to take a picture of the TV in operation since I don't have the panel.​
                                    • lotas
                                      • Jan 2016
                                      • 4854
                                      • Russia
                                      #38
                                      Congratulations, it means everything will work...
                                      • Alex Corps
                                        • Mar 2025
                                        • 25
                                        • France
                                        #39
                                        Well, in any case, thank you very much for your time and the modification of the dump, I did not know this failure.
                                        • Diah
                                          • Feb 2013
                                          • 6560
                                          i would love to see photo please
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            09-06-2024, 06:20 PM
