Samsung LE32M87BD No contrast
  • andyanz
    • Mar 2014
    • 7
    • Wales UK
    Hi, I see a lot of this type of tv but never had this fault. Set works but there is no contrast. Menu bars move left to right but no change. Done usual eeprom reset and fitted new eeprom. still the same. Psu caps etc all ok. Any ideas. Im thinking main board ?
    Re: Samsung LE32M87BD No contrast
    post a screen shot so we can see what the picture looks like.
    More likely to have AS15 GAMMA IC (U402) problem in the T-CON board.
    http://www.shopjimmy.com/media/catal...5531T03112.jpg
    http://www.shopjimmy.com/catalogsear...sung+LE32M87BD
    • andyanz
      • Mar 2014
      • 7
      • Wales UK
      . hi thanks for reply. I hope i have uploaded pics ok as first time in trying. Contrast n brightness controls move but have no effect. bright screen with no depth. When pressing menus the last one can still be seen before fading. t con is. T315XW02 v6. Many thanks in advance
        Looks like a gamma IC fault. Post a picture of the T-con board.
        • andyanz
          • Mar 2014
          • 7
          • Wales UK
            Please take a picture in focus, we need to see the small text and small components on the board. In particular along the bottom of the board.
              • 31024
              do these AS15 chips run hot?
              just wondering why they all die.
                They usually do not run above about 35°C (barely warm to the touch), and since the output fault affects multiple channels, it seems like it is some kind of internal bias or compensation circuit gone wrong.
                  Tom, This picture may help. Provided by SJ.
                    Yes so andyanz will need to test the VGAMA points from 1 to 22 (some missing) on the right hand side of the board, just under right most ribbon connector.
                    • andyanz
                      • Mar 2014
                      • 7
                      • Wales UK
                      Thanks guys you have been fantastic. Ive ordered a replacement t con today. will post the results when fitted. Many thanks again
                        You did not test the gamma voltages VGAMA to see if the original T-con is actually bad...?
                        • andyanz
                          • Mar 2014
                          • 7
                          • Wales UK
                          Took a gamble as top ribbons are difficult to get too as hidden under top frame.
                          • andyanz
                            • Mar 2014
                            • 7
                            • Wales UK
                            Fiited another t con. all working fine now, many thanks for everyones help
                              Thanks for the follow-up.
                                09-07-2024, 05:50 AM
                              • Jacksoft
                                Samsung 225MW EEPROM bootloop
                                by Jacksoft
                                I got an old Samsung 225MW TV with BN41-00825 motherboard.
                                Since the TV has a buzzer when it starts it makes a beep. The main problem is that the TV goes in a sort of bootloop and beeps every 2-3 seconds.
                                So I attached the VGA UART cable and read the debug data using a RT809H programmer:
                                According to the Service Manual all the voltages looks good, so I made a backup of the internal flash and all the EEPROMs (1 Settings + 3 EDID) and cleaned the EEPROM.
                                Now the TV boots but it's stuck on VGA. If I try to change the source it goes to TV, restarts...
                                02-14-2025, 04:18 PM
                                09-06-2024, 11:40 PM
                                09-06-2024, 08:40 PM
