LG 47CS570-UD 47" LCD TV - NO Picture/Sound
  • GeforceXtreme
    • Jun 2014
    • 11
    Hello all. Hopefully you can shed some light on the issue I am dealing with my spare bedroom TV. I have a LG 47CS570-UD 47" LCD TV. Its build date is in sometime in 2012 and since getting the TV in 2013, it hardly was ever used. Well at the end of 2013 I tried to turn it on and nothing. The red light blinks two times and turns blue like it normally would when powered on. However we get no display or sound from the TV. It acts like it's not even on what so ever besides the blue light.
    We have tried the hard reset method on it and still no luck. Being I am unable to find any information online about what this exact issue is, I was trying to find out if a certain part has failed (which I can order) or there is something else I can do? This TV is just so new for us not to consider trying to somehow get it working again.
    I have already opened the TV up and I didn't see anything that could be damaged. All the capacitors still look perfectly fine. I was thinking maybe it was a power supply issue. But after checking out what I could with a volt meter, power looked fine… I am just not sure if I should try replacing the power supply or look into replacing the mainboard? It seems many online suggest to replace mainboards in LG TV? I just wish I knew what the issue was so if the part I am buying, will actually fix the TV and I am not guessing?
  • dcapper
    • Dec 2013
    • 496
    Re: LG 47CS570-UD 47" LCD TV - NO Picture/Sound
    The Toshiba's are known for a bad eeprom. Maybe LG could have some sort of problem too? I would suspect it's in the mainboard if you are getting voltages out of the power board. Check all your fuses on all the boards too.
    • GeforceXtreme
      • Jun 2014
      • 11
      Yeah Fuses looked good but I will double check.
      Can I just buy a replacement Mainboard swap it in and hope for the best?
      It appears the Mainboard part/model number is EAX64290501
      • dcapper
        • Dec 2013
        • 496
        I don't know if the boards have to be an exact match like Panasonic. I don't think so. Search it or your model number on shopjimmy. It will give you an exact match. If they don't have one, check tri state module, moduslink tv parts, and payless components. I have had great luck with all three of them. I even have had good luck on ebay.
        • GeforceXtreme
          • Jun 2014
          • 11
          That's my only concern. But reason why I am trying to find the same matching model #. I have been lucky to see them on ebay for pretty cheap. Guess I will try replacing the main board with a replacement one to see if I get lucky and it fires on... Thanks for the suggestions of the other websites to buy from.
          • dcapper
            • Dec 2013
            • 496
            I see there is alot of tv's with that number you posted. Make sure you get the right number from shopjimmy. Also, make sure your panel sticker matches the ones from shopjimmy to get the exact part you need. I see there is two different versions for that tv.
            EBR73114017 and EBT61983003
            But they have the same panel sticker number and the same notes. Got me which one you need. Maybe look at the pics and see which one looks like an exact match.
            • GeforceXtreme
              • Jun 2014
              • 11
              I pulled the tv apart again to look at the board in detail. There is an orange sticker that says EBT61983003. Then there is a white sticker not far from the orange one that says EBR74404706. I found a EBT61983003 on ebay pretty cheap so I guess I will try that one.
              I just wonder if LG made a newer model of the same board to possibly fix what could be a common issue with the one I currently have?
              • GeforceXtreme
                • Jun 2014
                • 11
                So I swapped the replacement main board into the TV yesterday and luck would have it fired right up like it was never broken. So seems the common issues on this is the mainboard failing. Hopefully this mainboard lasts longer then the less then 1 year I had with the original.
                • Ierwin
                  by Ierwin
                  05-13-2025, 03:31 PM
                • Tr0ll
                  by Tr0ll
                  Original T-con:
                  First replacement T-con:
                  10-07-2023, 07:48 PM
                • Mgiffune
                  by Mgiffune
                  06-09-2024, 10:28 AM
                • Nairolf
                  Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                  by Nairolf
                  I have a Samsung DM32D display.
                  When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                  Here’s what I have tried so far:
                  1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                  2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                  3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                  From these tests, I suspect the problem might be on the mainboard. Could anyone...
                  08-24-2025, 03:47 AM
                • benspawn02
                  Anthem MRX500 - no sound. R2A15218FP issue??
                  by benspawn02
                  Dear Electronics Experts:
                  I have the following problem I am trying to troubleshoot. Unfortunately, I have contacted Anthem themselves and even a local distributer but I am not having much luck. Also, I have scoured the internet and unable to obtain a service manual. The Anthem service rep has also replied that he is unable to provide me with any service documentation. I have performed numerous searches on the internet and cross-referenced a few other AV receiver makers (Denon, Marantz, Onkyo) and found certain similarities to block diagram...
                  08-12-2023, 04:46 AM
