LG 49UB850V Start Up Issue
  • Andi29681
    • Feb 2025
    • 8
    Hello Community,
    I‘m Andi and I have some issues with my LG 49UB850V.
    My TV turns on and the LG Logo appears for 1 sec.
    After that the TV screen stays black but the backlight stays on.
    No reaction on the remote or knob. I can’t open the menu.
    The 2 LEDs on the Mainboard stay constant red.
    If I plug in a usb drive with current firmware the TV detects the flash drive and I get a notification on the screen to install the firmware. I can't install a new firmware. It looks like the menu is frozen.
    Do you have any ideas?
  • Diah
    • Feb 2013
    • 6437
    at the same way try use usb mouse or air mouse to see if it response for upgrade matter. even try reduce load by disconnect WIFI / BT
    • Andi29681
      • Feb 2025
      • 8
      I plugged in an other usb device and it gets power.
      It looks like that the TV operating system is not starting up.
      • Nugzzy
        • Dec 2024
        • 9
        • Portugal
        Hi
        Attached is the Service Manual
        It may help you or others - good luck with the repair!
        Cheers
          LCD LED TV Service Menu Codes
          ALL LCD LED TV SERVICE MENU CODES
          Service Menu Code with Board Name
          China Universal Board / Jumper Board Service Menu Code
          Changhong Ruba Service Menu Code
          Ecostar LED TV Service Menu Code
          Orient LED TV Service Menu Code
          Haier LED TV Service Menu Code
          TCL LED TV Service Menu Code
          Samsung LED TV Service Menu Code
          LG LED TV Service Menu Code
          Videocon LED TV Service Menu Code
          Supra LED TV Service Menu Code
          Toshiba LED TV Service Menu Code
          Symphony LED TV Service Menu Code
          Veste/ LED TV Service Menu Code...
          10-31-2024, 03:58 AM
        • zklgfs
          Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
          by zklgfs
          I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
          08-11-2025, 02:14 PM
        • wattage
          AOC AG493UCX 49-inch monitor - Firmware request
          by wattage
          Hello Badcaps Community,
          The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
          07-13-2025, 04:41 PM
        • Robby-Gr
          TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
          by Robby-Gr
          I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
          However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
          The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
          Additional issues:...
          09-27-2025, 12:02 AM
        • titomno2
          Surface Pro 7 type 1866 PD controller firmware issue
          by titomno2
          Hi guys,
          Hope you are fine.
          I'm struggling to fix a small issue with one of the tablet Surface Pro 7 type 1866 i'm fixing (windows 11).
          The boot time is so long (up to 5-10 minutes).
          After several attempt I finally find one thing is not right (PD controller firmware is 0.0.0 it can't update to 3.6.1) under device manager I have a yellow mark, code 14 and error as decribed on picture attached.
          I don't find any information regarding the error code 0x1803 (and sometimes it change to 0x1804.
          In the past I have found that if the update is a success, the boot...
          04-27-2025, 01:02 AM
