LG 49UB850V Start Up Issue
  • Andi29681
    • Feb 2025
    • 8
    Hello Community,
    I‘m Andi and I have some issues with my LG 49UB850V.
    My TV turns on and the LG Logo appears for 1 sec.
    After that the TV screen stays black but the backlight stays on.
    No reaction on the remote or knob. I can’t open the menu.
    The 2 LEDs on the Mainboard stay constant red.
    If I plug in a usb drive with current firmware the TV detects the flash drive and I get a notification on the screen to install the firmware. I can't install a new firmware. It looks like the menu is frozen.
    Do you have any ideas?
  • Diah
    • Feb 2013
    • 6679
    at the same way try use usb mouse or air mouse to see if it response for upgrade matter. even try reduce load by disconnect WIFI / BT
    • Andi29681
      • Feb 2025
      • 8
      I plugged in an other usb device and it gets power.
      It looks like that the TV operating system is not starting up.
      • Nugzzy
        • Dec 2024
        • 9
        • Portugal
        Hi
        Attached is the Service Manual
        It may help you or others - good luck with the repair!
        Cheers
        • lledofranky
          • May 2026
          • España
          hola amigo me pasa con lo mismo que a ti , necesitamos los dump de reflasheo , pero no los encuentro por ningun lado , mi tv es lg 49ub8550-zd
          • Boardview and Schematic Bot
            LCD LED TV Service Menu Codes
            TCL LED TV Service Menu Code
            LG LED TV Service Menu Code
            10-31-2024, 03:58 AM
          • FluxCapacitorish
            Aiwa TV-49UF30H (VM6901 / LC490EGY) stuck in bootloop, need install.img firmware dump
            by FluxCapacitorish
            I’m working on an Aiwa TV-49UF30H that is currently stuck in a bootloop. I’ve done a full teardown and diagnostics and wanted to see if anyone has a firmware dump or matching install.img.
            Symptoms:
            • Without USB: power LED flashes, TV immediately shuts off (bootloop)
            • With USB (install.img): green LED + grey screen (appears to enter recovery mode but does not proceed)
            What I’ve confirmed:
            • Main chipset: VM6901
            • Storage: eMMC (Kioxia THGBMNG5, integrated MCP under heatsink)
            • No SPI flash present on board
            • USB recovery bootloader is working and detects
            04-06-2026, 03:04 AM
          • zklgfs
            Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
            by zklgfs
            I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
            08-11-2025, 02:14 PM
          • wattage
            by wattage
            Hello Badcaps Community,
            07-13-2025, 04:41 PM
          • Robby-Gr
            TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
            by Robby-Gr
            I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
            However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
            The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
            Additional issues:...
            09-27-2025, 12:02 AM
