Sony KDL40S2000 IR remote sensor no longer works
  • X5-452
    • Apr 2014
    • 13
    I have a Sony KDL40S2000 LCD TV. That can no longer be controlled via the remote. I've tried several universal remotes and also verified the OEM remote works with another TV. Also tried pointing the remote at a camera and the IR beam is visible. I've never heard of these IR receivers going bad before. I'm wondering if this could just be due to a lose cable or something similar.
    Any help is appreciated.
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: Sony KDL40S2000 IR remote sensor no longer works
    wow,second one in a day .....
    You need to look at this video
    http://www.youtube.com/watch?v=imF8_DHUPmU
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • X5-452
      • Apr 2014
      • 13
      Thank you! That's extremely helpful.
      • Carlos#2003%
        Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
        by Carlos#2003%
        Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
        02-15-2024, 07:52 PM
      • snme
        Sony remote control RM-GD007 glued?
        by snme
        Have not found a manner to open this remote without a hammer or grinder.
        So far as I can tell, there is no manner to decently open it and remove oil from the contacts.
        Any secret technique would be welcome.
        09-12-2023, 04:20 AM
      • foxer
        Sony AV1010, basically works but heatsink is cold, resistors overheating
        by foxer
        Weird stuff.
        I press power on this receiver, I hear the relay click, I can play music and get radio, everything apparently works but not really. The big heatsink stays cold to the touch, the small heatsinks to the two voltage regulators on the mainboard get super hot, and there are two overheated brown areas on the mainboard with an identical pattern (circled in red), centered on the components on each side of the big capacitors (removed in these pictures). Those last components, of course, also get burning hot.
        So...I spent the week with my novice skill trying to locate...
        06-19-2023, 07:54 PM
        Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
        This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
        09-06-2024, 05:27 AM
      • Mc_Millian
        Toshiba 50lf711u20 fire tv remote not pairing
        by Mc_Millian
        I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
        The Tv model number is: 50lf711u20 Rev B.
        I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
        I've tried 3 different remotes which should be fully compatible with this TV.
        Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
        The power button, along with the volume,back,select, and directional...
        04-07-2022, 12:15 PM
