LG 50PA4500 Clicking troubleshooting HELP please...
  • Hamie
    • Apr 2014
    • 1383
    Re: LG 50PA4500 Clicking troubleshooting HELP please...
    Yeah m-on and stby
    Sometimes it's printed a bit clearer on the underside of the board.
    • Fwrothy
      • Feb 2014
      • 178
      I'd like to pick up where this thread left off: got the same model LG with the same symptoms. PSU P/N:EAY62609701
      Have disconnected all cables to psu except line voltage and jumped M.ON to STBY
      The relay clicks twice and there are no output voltages except 5.2vdc STBY
      • Brentsky
        • Oct 2013
        • 46
        Do you have a way to take an up close picture of your TV's power supply ?
        • Fwrothy
          • Feb 2014
          • 178
          Both sides?
          • Fwrothy
            • Feb 2014
            • 178
            My psu
            • Fwrothy
              • Feb 2014
              • 178
              ...and this
              • Brentsky
                • Oct 2013
                • 46
                Replace C802 Capacitor (circled in the photo below) It can be found on ebay.
                223J@1250V HIGH PULSE. If your unable to perform this repair I can assist you if needed.
                • Brentsky
                  • Oct 2013
                  • 46
                  By the way this is turning into a common problem with this model of power supply.
                    Thanks for the info very useful. The poly cap in a lot of these half-bridge type power supplies is a frequent failure. Some models seem immune and yet others have tons of issues. Wonder why, seems like it might be a parts sourcing/quality issue rather than a design issue. Have seen 15+yr old PSUs with those caps still OK.
                    • Fwrothy
                      • Feb 2014
                      • 178
                      So it looks like that cap is a .022uF @ 1.25kvdc pp. I'm not partial to eBay so ordered a hopefully suitable substitute from digikey last night; should be here by end of day... we will see if that's the fix...
                      Thanks guys!
                      • Mac 108
                        • Jul 2014
                        • 30
                        What's the part number for that cap?
                        • Fwrothy
                          • Feb 2014
                          • 178
                          Like I said its a substitute, here is the data sheet:
                          Maybe one of the more knowledgable guys can review this...
                          Part# is B32612A7223J008 it's rated high pulse and application include SMPS, I've got 10 coming and will post results but caution you to use at your own risk.
                          • Fwrothy
                            • Feb 2014
                            • 178
                            I haven't even taken c802 off of my board yet to test it...
                            • Fwrothy
                              • Feb 2014
                              • 178
                              Ok the new caps arrived; took out c802 and tested it-nfg
                              Checked the new cap- on spec@ .0215uF
                              • Fwrothy
                                • Feb 2014
                                • 178
                                Ok new cap in and board remounted in chassis...
                                Left all cables but AC disconnected.
                                Powered up psu-ONE RELAY CLICK!
                                Checked voltages at main cap- ~390vdc
                                Jumped M-on to STBY, all voltages including VSTP & VATP check out.
                                Power down, reconnect Y&Z sus cable and main board cable.
                                Plugged it back in and it Works!
                                  Nice fix, thanks for sharing!
                                  • Fwrothy
                                    • Feb 2014
                                    • 178
                                    Thank you brentsky for this solution!
                                    Still not sure of the compatibility of the substitute cap- but so far so good-Comments?
                                    • skyver
                                      • Feb 2015
                                      • 31
                                      i cant post a new topic as im a new member but
                                      I have a 60PA6500
                                      It switches between either
                                      *constant relay click
                                      or
                                      *stuck in some standby mode where the screen is on but blank , power LEF is red and control board D101 Led blinks fast then slow then pauses
                                      weird thing is every now and again the TV works fine for a few days then back to this.
                                      when its in its constant relay click boot it will do this with just the power and main board connected and all other boards unplugged
                                      any help an ideas?
                                      POWER SUPPLY EAX64276701/11 EAY62609801
                                      • skyver
                                        • Feb 2015
                                        • 31
                                        i have completed an auto gen test and the screen cycles through different colours, so from what ive read that means its a mainboard problem?
                                        what can i test on the main board?
                                        • skyver
                                          • Feb 2015
                                          • 31
                                          Mainboard is an EAX64696607 (1.0)
                                          • B0r1s
                                            Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                                            by B0r1s
                                            PSU - BN44-00878A
                                            Symptoms:
                                            The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                                            A weak clicking sound was coming from the transformer.
                                            Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                                            Progress:
                                            After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                                            01-17-2023, 04:58 PM
                                          • blues_spirit
                                            practical courses for troubleshooting pc motherboards
                                            by blues_spirit
                                            Hello from France,
                                            mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
                                            Do you think this is feasible for me? I...
                                            12-18-2022, 12:56 PM
                                          • slimmy182
                                            [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                            by slimmy182
                                            Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                            I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                            Looking on google I found this:...
                                            01-14-2023, 11:55 AM
                                          • beetle1303
                                            Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                            by beetle1303
                                            I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                            On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                            01-13-2025, 08:49 PM
                                          • gcrezz
                                            GV-N2060OC-6GD REV 2.0 GIGABYTE video card troubleshooting assistance needed.
                                            by gcrezz
                                            The issue with this video card is the HDMI port. Specifically on pin 19 (Diode checks on all other pins are normal). When i do a diode check on it from the pin on the board itself, I have nothing. There is also no short on the pin. Resistance reads about 200k. Normally on any HDMI pin 19 I would expect some voltage drop anywhere from .5v to 1.2v but here, I have nothing. The card is operational and can be used via the displayPort ports, but not through the HDMI. Attached you will find the pdf schematics for the card on page 22. I have verified that all of the resistors on this line before the...
                                            07-25-2024, 09:49 AM
