UE55MU6120KXTZ SAMSUNG IT DOES NOT TURN ON
  • geck7
    • Dec 2018
    • 12
    • Catania
    Hi Lotos could you check my dump file because my samsung tv won't turn on.
    Thanks Click image for larger version  Name:	WhatsApp Image 2025-01-03 at 18.45.46.jpg Views:	25 Size:	103.0 KB ID:	3541109
  • lotas
    • Jan 2016
    • 4479
    • Russia
    Yes, I can check, but I don't see any dump. What you posted. This is a photo of the motherboard, not a dump.
    • geck7
      • Dec 2018
      • 12
      • Catania
      dump
      • lotas
        • Jan 2016
        • 4479
        • Russia
        Originally posted by geck7
        dump
        Strange damage to the dump, what was the behavior with the TV, what didn’t work, was the standby LED on? Try this dump, after recording, do not forget to set and write the status register (0x88, 0x42).
        • geck7
          • Dec 2018
          • 12
          • Catania
          The defect that TV makes and what turns it on and off
          • lotas
            • Jan 2016
            • 4479
            • Russia
            Well, turn it on and off (reboot), most likely due to a malfunction of the panel, when you disconnect the lvds cable from the motherboard, is it also overloaded? If the dump 25Q40 TV is damaged, it does not turn on at all, and the standby LED does not even light up.
            • geck7
              • Dec 2018
              • 12
              • Catania
              By disconnecting the LVDS cables the TV also turns on the backlight
              • lotas
                • Jan 2016
                • 4479
                • Russia
                When the lvds cables are disconnected and the backlight should light up, the question was - did the reboot remain or not?
