UE55MU6120KXTZ SAMSUNG IT DOES NOT TURN ON
  • geck7
    • Dec 2018
    • 12
    • Catania
    Hi Lotos could you check my dump file because my samsung tv won't turn on.
    Thanks Click image for larger version  Name:	WhatsApp Image 2025-01-03 at 18.45.46.jpg Views:	25 Size:	103.0 KB ID:	3541109
  • lotas
    • Jan 2016
    • 4621
    • Russia
    Yes, I can check, but I don't see any dump. What you posted. This is a photo of the motherboard, not a dump.
    • geck7
      • Dec 2018
      • 12
      • Catania
      dump
      • lotas
        • Jan 2016
        • 4621
        • Russia
        Originally posted by geck7
        dump
        Strange damage to the dump, what was the behavior with the TV, what didn’t work, was the standby LED on? Try this dump, after recording, do not forget to set and write the status register (0x88, 0x42).
        • geck7
          • Dec 2018
          • 12
          • Catania
          The defect that TV makes and what turns it on and off
          • lotas
            • Jan 2016
            • 4621
            • Russia
            Well, turn it on and off (reboot), most likely due to a malfunction of the panel, when you disconnect the lvds cable from the motherboard, is it also overloaded? If the dump 25Q40 TV is damaged, it does not turn on at all, and the standby LED does not even light up.
            • geck7
              • Dec 2018
              • 12
              • Catania
              By disconnecting the LVDS cables the TV also turns on the backlight
              • lotas
                • Jan 2016
                • 4621
                • Russia
                When the lvds cables are disconnected and the backlight should light up, the question was - did the reboot remain or not?
                • unimatrix93
                  SAMSUNG UE58MU6122 dump file needed
                  by unimatrix93
                  Dear Community,
                  I have a Samsung UE58MU6122 with no power LED.
                  I checked the PSU, all output voltages are present so it's probably good.
                  Doing some research I found that the corruption of the SPI memory chip can cause this problem and the TV started acting like this after a power outage.
                  Can somebody please provide a dump file so I can flash it to the IC?
                  Thank you!😊
                  02-29-2024, 03:15 AM
                  09-07-2024, 05:50 AM
                • GeckoGreen
                  Samsung service bulletin: need firmware file for PN63C550 TV
                  by GeckoGreen
                  I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
                  You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
                  The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
                  Will you please help me get the [2D63]LOGIC.bin file for my TV?
                  05-17-2025, 02:47 PM
                • Citymin
                  by Citymin
                  S/N : 5RNK9FFT70...
                  08-05-2025, 05:12 AM
                • G11NS
                  Samsung Subwoofer HK-450 Transmitter Dump file repair
                  by G11NS
                  Hi, need help to fix my dump file....
                  It was Samsung Subwoofer HK-450 Transmitter
                  Model : WISP-40A RX1
                  P/N : AH59-02738A
                  FW : R140
                  Thank you for help.......
                  02-25-2023, 10:34 PM
