I have no picture on my TV but have audio. This is a Walmart black Friday TV. I looked a cable that everybody else gas trouble with but it is good o ohmed out and is working. What board would I need to replace to fix this TV.
Emerson ltdn42v68us, 42" LCD
Tags: None
Re: Emerson ltdn42v68us, 42" LCD
Post close up pictures of the boards inside your set. Right now, its hard to say. Vizio's can have any board failure and produce the similar symptoms. Though, Sound and no video... I'd check the slave inverter board first though it could be any.The strong-minded rise to the challenge of their goals,the weak-minded BECOME HATERS
by fharris1977Hello. I have an Emerson lcd set and it won't turn on with remote or button board on set. It shows a solid red standby led. I suspected the eeprom(N10) so I replaced it but still same results. I still suspect the main board as the culprit, please correct me if I'm wrong. If it is the main board could antone direct me to repairing it? Thanks in advance....
by Mustafa85Hi guys,
Any one has Emerson industrial PSU schematic, it has 3 electronics cards in one package please have a look at pics -
by littlejohnHello I have a Emerson research clock radio model CKS3516C and the transformer went out on it ,the label on the clock radio says 120VAC 6 watt backup battery DC 3v CR2430. the numbers on the transformer ST3591C-13SEN which I can't find anywhere for it. Can anyone please tell me the AC output voltage. Thanks
by gmgmI need dump bin for Emerson model lf320em5f...
by supergHi all, I am looking for the COF datasheet for the panel of this TV. The part number is MT3228A-VA....04-04-2025, 09:46 AM
- Loading...
