Westinghouse SK 26H735S/Liteon PB 4131-12V fails under load
  • smoothcriminal69
    • Jun 2014
    • 16
    • US
    Good morning folks,
    I have already replaced this board once, and it seems my Ebay board has died now also. Specs are as follows
    12v-11.7
    24v-23.6
    5v-5
    all caps test ok, out of circuit and plus or minus 10% or so uf on my fluke.
    Power on the 12v rail falls under load to 4-5v(tested with my handy dandy test fan).
    AS I'm sure you gents will know exactly whats happening, please be gentle as I am at best a weekend warrior.
    America-well we used to fix our own stuff, now we just buy new...
    Re: Westinghouse SK 26H735S/Liteon PB 4131-12V fails under load
    Can we see good clear pictures of the bottom side of the board and around the connectors also?
    • Caleb
      Smokin IC's
      • Feb 2013
      • 645
      Are those two large current limiting resistors within spec?
      Liberating magic smoke one part at a time
      • smoothcriminal69
        • Jun 2014
        • 16
        • US
        And yes I know there are some cold pools, they are the legs of heat sinks, My iron does not have da powaa!!
        The resistors at r300 and r201 are good.
          Can you do straight shot and make sure it is well focused since I need to be able to trace out those connections?
          • smoothcriminal69
            • Jun 2014
            • 16
            • US
            There are quite a few caps out, check-check-and re-check right...
            • yaya3gmax
              Laptop Power Issue – Works on Battery, Fails on Adapter Load
              by yaya3gmax
              Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
              Symptoms:
              • Laptop works normally on a pre-charged battery.
              • Battery does not charge when adapter is connected.
              • Without battery:
                • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                • Speakers “pop” when power cut occurs indicating harsh sutdown.
                • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
              08-21-2025, 07:16 AM
            • AJ847.63e
              Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
              by AJ847.63e
              Hi Folks,
              Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
              I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
              The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
              05-06-2025, 10:37 PM
              HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
              This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
              09-12-2024, 02:20 PM
              HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
              This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
              09-06-2024, 10:56 AM
              HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
              This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
