Samsung UN49MU6300 no power
  • Jimvarela
    • Nov 2015
    • 9
    • Colombia
    I have this model tv with board BN41-02568B
    no power, i need check my dump , i apreciate help
  • lotas
    • Jan 2016
    • 4900
    • Russia
    Your dump is damaged, I fixed it, try it, don’t forget to set the status register (0x88, 0x42) after the entry.
    • Jimvarela
      • Nov 2015
      • 9
      • Colombia
      Thank you lotas!
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • Andreas_de
        Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
        by Andreas_de
        Hello!
        i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
        Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
        Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
        04-12-2025, 10:38 AM
      • mrtek
        Samsung UN43NU6950FXZA No power
        by mrtek
        Hi
        Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
        Main fuse = OK
        Back light LED = OK. Power them with aux power source
        LED output = OK 156V
        I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
        Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
        07-20-2025, 08:06 PM
