Having difficulty getting hold of schematic diagram of the SC/Ysus board used in this receiver ( TNPA5335 ). Anybody got a copy?
Panasonic TXP50VT30 ysus repair
Re: Panasonic TXP50VT30 ysus repair
The SC board was s/c on SC2 caused by all the following components going s/c D421,Q403,Q402,Q401,D401,Q423,Q422 and Q421. Fitted the repair kit and also replaced Q531 and ic502 included in the kit as a precaution. Followed the correct procedure by linking SC50 and the board worked ok without SD and SU connected. Connected SD and SU boards and removed SC50 link. Everything worked fine for 15 -20 minutes then 7 blink error code started again. On checking all the above replaced components had once again gone short circuit.
Any body know the most likely cause for this to happen?Last edited by satinser; 06-08-2014, 11:24 AM.Comment
Tough one to give much advice on. Bit like knowing why these fail in the first place.
getting 15 -20mins then same failure, makes me wonder whether a part was overheating and then failed, bad earthing screws, or substandard parts/fakes?
Any tech support from the kit provider?
Someone had a moduslink board fail fairly quick, sent it back, got it repaired again and second time round seemed ok. Forget which series, 2011/12?
Not that I'm suggesting getting another kit from the same supplier.
If the picture was fine, I would be inclined to assume the screen and buffers were ok.
Maybe ditch repairing it and see if you can score an original board instead.Comment
Appreciate your comments. I also belief its heat related which is also I in all probability the reason why they fail in the first place. I bought the repair kit from an Ebay seller but have now ordered individual components from Charles Hyde ( trade seller) and in so doing paid about 50% less.
I belief that the dissipation of heat from the rear of the component to the solder pad on the board is the all important factor that could lead to premature failure if not soldered tight to board. I will have to pay more particular attention to this when the components arrive. I will keep you informed of the outcome.Comment
by DAVEMAC02Does anyone have service or repair manual for Panasonic RA-6500 or RA-6600 combo radio receiver?
05-18-2025, 11:19 AM -
...1 Photo11-20-2024, 08:52 PM -
by SMDFleaCopying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....-
Channel: BIOS Requests ONLY!
by AquaMan UaHello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...2 Photos
by CaimanoUPDATE of JANUARY 5th : I am cancelling this post because problem has been solved by creating a new bios starting from the old one with correct dmi and cleaning ME. everything works fine . thanks anyway
Hi, I am replacing a motherboard circus-6050A2723701-MB-A02 to an HP 650 G2 laptop because the original one was faulty. I bought and repaired a used MB which works fine now with its BIOS, but I wanted to copy the DMI data from the old to the new MB. I created with Flash Image Tool a new bios starting from the old original chip , cleaned ME region and new updated dump region extracted...-
- Loading...
