Vizio Model: E390i-A1
  • _mannie411
    • Nov 2024
    • Nigeria
    Hi Guys,
    Brand: Vizio
    Model: E390i-A1
    Panel Brand: AUO
    Panel Model: T390HVN04.0
    Issue: initially the panel was showing double image/flickering. Then I tried the AUO level shifter ic bypass method, now the panel is showing vertical lines no image.
    Please any will be much appreciated.
  • howardc64
    Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
    by howardc64
    Failure Symptom
    No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
    Where is the short?
    Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
    Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
    05-27-2025, 02:56 PM
  • howardc64
    Vizio M557-G0 1/2 panel VGHD LC1 (and maybe XON VSSQ LC2) Problems
    by howardc64
    Failure Symptom
    No Display. Just random blocks of grouped vertical red lines.
    Disconnect right 1/2 panel (rear view), left 1/2 displays properly
    Masking T-Con Signal Diagnostic
    Reduced masking to 5 signals on right 1/2 panel and get perfect picture
    Pins are
    1 GND
    2 VGHD
    3 XON
    4 VSSQ
    5 LC2
    6 LC1
    VGHD and LC1 masking is absolutely necessary to get working panel. Didn't unmask 3-5 individually.
    Pictures and Schematic
    XON, LC2, LC1 are on AUO s302-21 32pin QFN...
    10-14-2024, 01:30 PM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
    HP ZBook 15u G2 Base Model Notebook 15 Specification for Upgrade or Repair
    This specification for the HP ZBook 15u G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15u G2 Base Model boardview and 15u G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
    09-06-2024, 05:27 AM
  • howardc64
    LG 49UJ6500 LCD panel lighter band that goes away
    by howardc64
    49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
    Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
    02-19-2023, 12:13 AM
