42PB4D-AA Power PCB VS 4A fuse blowing - suggestions?
  • matthewr88
    • May 2014
    • 10
    Hi guys,
    Ive got a LG 42" plasma here thats got an issue on the Power PCB, firstly ive read the basic guides put on here(very informative btw) and did a forum search before starting a new thread, but im after a little more specific advise
    The first issue noticed is the power light would be on stndby at the front of the tv, pressing the power button or applying power you could hear a relay fire after a couple of seconds.
    So the first thing i did was checked the input fuse all good, the board was so dusty at the time i couldn't even see the second one between the heatsinks.
    I checked the boards output, 5v = 4.8v steady, but the VS and VA would both go up to around 58~v then the relay would fire and back to 0v
    after giving it a damn good clean out I found the blown 250v 4A fuse(pictured below) in the center of the board, replacement just blew again, removed all other connectors to the power PCB and tested again same result. Fuse blows as soon as power is applied.
    So im guessing the issue is with the VS power circuit, Im also at this point guessing its a short as the fuse really pops when powers applied
    Inspected the board and i cant see any bloated caps or dry joints, all that said i need to start chasing the circuit, can anyone with a bit more experience with plasmas point me to a possible source.
    Power PCB model number is: EAY32808901
    5v, VA=61 VS=190
  • tw2005
    • Oct 2011
    • 6458
    Re: 42PB4D-AA Power PCB VS 4A fuse blowing - suggestions?
    I'd start with checking the FETs on the heatsinks, possibly the 2 on the opposite side of the fuse. I'd also check the Vs inputs on both the ysus and zsus boards and see if they're shorted too or Possible blown IPMs .
    The PSU may not be the only failed board in this TV. Best to find out now before you start sinking more $$$ than it's worth.
    Not familiar with LGs , someone else may have worked on this generation.
    • matthewr88
      • May 2014
      • 10
      cheers, will start there and post results
      • matthewr88
        • May 2014
        • 10
        Quick update during my lunchbreak
        So ive checked the VS inputs on both the ysus and zsus. No shorts between the VS and Ground rails, The YSUS boards fuse is still in tact which im guessing is a good sign.
        So on checking the FETs i have found the two tw2005 mentioned were indeed faulty (shorted) I believe. Checked them with a Metre and had a ~0 Ohm reading so that im taking as a short?
        Would anything else be damaged by these two going to short?
        Hoping fuse will have prevented too much damage
        Havent done any more research on the FETs themselves or anything else around. busy day at work fixing everyone elses problems lol, will investigate further tonight.
        • matthewr88
          • May 2014
          • 10
          Hi guys so after some futher testing, and a bit clearer head the FETs that i believe are dead are marked W20NK50Z all pins goto zero on the dmm from the data sheet its marked as a 500v 17A N-Channel FET
          does this sound right?
          can anyone confirm if i need to check any other circuitry surrounding this?
          cheers for any help in advance
            I would always replace any driver IC connected to the FETs, because it could also be damaged. Failure to do so could kill your new FETs on power up.
            • matthewr88
              • May 2014
              • 10
              Cheers tom66 exactly the information i was looking for
              • PantherDave
                by PantherDave
                Hi all!
                05-29-2024, 02:01 PM
              • GLISIT
                by GLISIT
                01-16-2025, 02:29 PM
              • Dannyx
                UC3842 Power Adapter Blowing Fuse
                by Dannyx
                Good day folks......wow this new layout is weird. It's like I woke up one day and I'm no longer on Planet Earth or something
                Anyway....got this here power brick from a USB to SATA adapter which keeps blowing the fuse after I almost repaired it. The reason I even bother to fix a power brick (wall wart, whatever) in the first place is because this thing was really convenient to use: I'd just plug it and that's it. It's a dual output supply, for both 12v and 5v, which although I COULD easily obtain with a DC-DC converter from a standard 12v adapter, I thought I should crack open the...
                12-05-2023, 12:06 PM
              • beetle1303
                Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                by beetle1303
                I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                01-13-2025, 08:49 PM
