Samsung QE65Q60RAT striped pattern with image in the background
  • SJX1290
    • Sep 2024
    • 28
    • Slovenia
    Hi, i got a Samsung QE65Q60RAT with dead MB, so I trayed with MB from 55" QE, and getting strange pattern on screen, but have menu in background, and TV is responding on commands,...Somebody any idea what can it be (picture)..faulty screen?
    thx
  • lotas
    • Jan 2016
    • 4862
    • Russia
    Firstly, you have different panels, which means the T-CON firmware will not match your panel, and secondly, if the panels are from different manufacturers, then there are position resistors on the motherboard and they must match your original motherboard...​
    • Diah
      • Feb 2013
      • 6568
      i am talking rs original MB. it could be repaired better than to swap T-CON SPI from old to other. as you have now different Panel profile
      so what are the issue with yours original MB ? dead no boot no front LED... if its so did you measured the rail of 3.3V of the start SPI if it shorted to chassis.. ?
      • SJX1290
        • Sep 2024
        • 28
        • Slovenia
        dead, taken out and somebody is messing with it,..basicaly left withouth MB so I am tying just to find out if is screen working to buy a new MB
        • Diah
          • Feb 2013
          • 6568
          trash bin
          • lotas
            • Jan 2016
            • 4862
            • Russia
            The panel is most likely alive, look for the motherboard number BN94-14007G.
            • Diah
              • Feb 2013
              • 6568
              lotas sines when Q6 Q7 Q8 panels remain alive .... ?
              • lotas
                • Jan 2016
                • 4862
                • Russia
                The panel does not have black vertical pillars, the TV does not turn off or reboot.
                • Diah
                  • Feb 2013
                  • 6568
                  it will do right away when correct MB in place... now CLK line missing just like masking
                  you write it correct at yours first post
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4540
                    • Italy - Milan
                    so I trayed
                    well, this is the english i like.. hihihi :-))''''
                    i think you need to search ebay not for MB model code but for Screen model code (sticker)
                    • SJX1290
                      • Sep 2024
                      • 28
                      • Slovenia
                      then 50/50 .... so, will go for parts
                      THX
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4540
                        • Italy - Milan
                        I explain better my theory, Samsung is from the stone era busy in planned osolescence techniques, between my last annotations, in main board searches (i do it very rarely) i noticed too much codes of the sticker type and also screen stickers, respect to the pcb code, my bet is that it doesn't exists technically so many variants, it's Samsung that varies them to confuse everyone, so maybe the correct search at first try on ebay could be
                        " (-your BN94-XXXXX-, -yourPanelcode-) -your BN41-xxxxx- "
                          09-07-2024, 05:50 AM
                        • shlomim412
                          samsung ua55es6800 - no image
                          by shlomim412
                          hi
                          having problem with samsung ua55es6800
                          tv had backlight on, sound working - responds to the remote control but no image.
                          check tcon board - had 12v in but no other voltages present.
                          when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
                          when leaving only left side connected - again no voltages and no image.
                          put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
                          kept trying to block less pins on the left ribbon cable...
                          05-15-2024, 05:00 AM
                          09-06-2024, 11:40 PM
                          09-06-2024, 08:40 PM
