Info PLS RE: TC-PxxST30 Svc-Menu Eeprom editor/Flash Utility
  • N9ZN-Extra
    • Apr 2014
    • 22
    I am needing as much information as I can gather about the built in Eeprom editor and flash utility built into the TC-PxxST30 series of Panasonic Plasma televisions. This includes a data sheet for the Peaks Eeprom, any code listing for the programs controlling the TV functions, and schematic info for the Peaks module IC.
    This utility is found in the Svc-Tool information display, it is hidden and can be made viewable by positioning your cursor in the top right box after which you must hold the MUTE button for 3 seconds to make it visible. You can select the utility by selecting it and pressing OK on the remote. Use the remote RETURN button to exit the data fields and the editor.
    Once back to the Svc-Tool information screen you can press and hold the remote RETURN button for approximately 5 seconds to return the set back to normal viewing after it reloads and reboots the television, the power light will remain lit during this process and the screen will go black for about 5 to 10 seconds before your television returns to the channel you were viewing.
  • ekozeko333
    by ekozeko333
    🧠 What I’ve Done So Far
    Flashed...
    06-21-2025, 02:48 AM
  • corrize
    Nikon D800 camera - flash don’t work and capacitor don’t charge
    by corrize
    Hello, I'm stuck in troubleshooting…
    The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
    In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
    When I press the flash button, it's detected by the system, flash icon appear on LDC display....
    10-01-2022, 10:02 AM
  • SidneyCanadas
    93C46 and 93C56 EEPROM
    by SidneyCanadas
    I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
    https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
    Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
    06-14-2023, 01:16 PM
  • acedogblast
    by acedogblast
    11-02-2024, 05:13 PM
  • abajor
    Canon VIXIA HF S10 A read data from inernal flash memory.
    by abajor
    Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
    Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
    The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
    I think my best shot is to figure out a way to read the internal flash memory outside...
    07-20-2024, 12:04 AM
